JMB RetrofitsVolks Autos
Results 1 to 27 of 27
    waveform2's Avatar
    * J e d i *
    Oct 2004
    Scotland
    435
    Problems with rear speakers
    Hi all,
    First post, and an instant question [img]/ubbthreads/images/graemlins/grin.gif[/img]
    I've got a 1998 a4 1.8 and since i gotit the rear speakers havent worked.
    Got the keys for removing the head unit but im still none the wiser.
    Any ideas how to troubleshoot whats wrong with them?
    Looks like the previous owner had a car kit installed as theres a panasonic speaker on the passanger side of the centre console, dont know if someone has messed with the wiring or not!
    Any help would be most appreciated. [img]/ubbthreads/images/graemlins/cry.gif[/img]
    Regards
    Derek
    Jun 2003
    World of my own
    9,813
    Re: Problems with rear speakers
    I'm assuming you don't have the Bose upgrade?
    The rears are powered by their own amp, bolted to the rear left speaker. It could be the amp isn't working, or that the carkit was installed and used the "remote on" wire so that the rear amp isn't getting the "12v switch on" it needs to power up.
    The rear amp uses the yellow mini ISO connector on the rear of the HU. This provides front & rear pre-outs and remote on. Depending how confident you are you could check that this hasn't been tampered with. Next would be to check at the amp, to see it is getting perm 12v and the switch on 12v, I have the pin-outs if you need them.
    waveform2's Avatar
    * J e d i *
    Oct 2004
    Scotland
    435
    Thanks for the quick reply, i didnt realise there was anything in boot i'll have a lookie tonight.
    And no Bose upgrade.
    Derek
    Feb 2003
    Lincolnshire/Bournemouth
    739
    The rears aren't connected at all, is that a DELTA head unit?
    Jun 2003
    World of my own
    9,813
    That's not the original head unit.
    Looks like someone has installed an older unit or something, as all the wiring has been connected via adapters. You have a black adapter taking the power and front speakers outputs from the original loom to the HU, and the big red connector (shown in the last pic), only has the rear pre-outs actually making their way to the HU. Nothing else seems to be connected. The light blue plug is the CD changer loom and the green plug is the DIS. The yellow one is the pre-outs/remote on, which is the only one connected. The connections should look like the photo below, with everything plugged straight into the HU.
    Also there are no helpful labels (like the remote on one shown) on an OEM install.
    The remote on should be connected to the yellow plug on the pin in the middle row that sticks out from the others. Check if this is connected and has 12v when the radio is on.
    Jun 2003
    World of my own
    9,813
    This is the standard pin outs on most Audi HU (shown from a Concert).
    waveform2's Avatar
    * J e d i *
    Oct 2004
    Scotland
    435
    Hi Again,
    This is the actual head unit, is this not the correct one?
    I'm only the second owner of the car and the bloke didnt mention anything about changing the HU out and i did ask if there were any electrical problems, he just mentioned the rear speakers.
    Derek
    Jun 2003
    World of my own
    9,813
    No, that's definately an Audi Concert HU, I just don't understand why the wiring has been butchered. Maybe the previous owner had an aftermarket unit fitted and then put the OEM one back in?
    You should be able to dispense with all the additional adapters. Just unplug them all and plug the Audi wiring directly into the HU. Thats the black power ISO, the brown front speaker ISO and the blue/green/yellow mini ISO, and the red CAN-BUS plug (if you have one).
    waveform2's Avatar
    * J e d i *
    Oct 2004
    Scotland
    435
    Sounds good, will give that a go in the morning, same here no idea why the wiring is like that, but hopefully will work when plugged back in as it should be.
    Thanks v.much for your help with this, most appreciated! [img]/ubbthreads/images/graemlins/cool.gif[/img]
    Will let you know in the morning how i get on.
    Derek
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    [ QUOTE ]
    Derek Ross said:
    Next quick question, where do i find the CD-Changer lead in the boot if its actually there?
    Dont want to start ripping trim off the boot in the wrong places.
    Regards
    Derek
    [/ QUOTE ]
    You should find that behind the fold down panel on the left hand side of the boot, where the "tool-kit" sits.
    BTW, welcome to the forum. [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    waveform2's Avatar
    * J e d i *
    Oct 2004
    Scotland
    435
    [ QUOTE ]
    [/ QUOTE ]
    I just seem to have a hole next to the spare wheel where the jack and toolkit are, i cant see a fold down panel?
    Derek
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    [ QUOTE ]
    Derek Ross said:
    [ QUOTE ]
    [/ QUOTE ]
    Derek
    [/ QUOTE ]
    The panel is part of the carpet-style trim on the left hand "wall" of the boot, just behind the wheel arch. It's about a foot square, and unclips, exposing a little shelf area. The CD loom is usually found behind there. I'll take a pic of mine later, and post it up for you.
    waveform2's Avatar
    * J e d i *
    Oct 2004
    Scotland
    435
    Thanks alot, i'm at work atm so i'll have a proper look later on.
    Derek
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Here's a pic of the boot with the side panel closed
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Ooops!! HERE'S a [pic of the boot with the side panel closed
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    & here's one of the panel open. As you can see, the tool box is on the top shelf, & the CD changer (not an OEM by the way, but an Alpine) sits on the shelf below. The CD-changer lead should be tucked somewhere in the space behind the shelf, just behind the wheel arch.
    Good luck!
    CraigM's Avatar
    Apr 2004
    Scotland, UK
    98
    The changer cable is underneath the jack/toolkit storage box: http://www.mcmillan-uk.com/A4CD.jpg - you need to remove this and you should find the cable tucked right down at the bottom.
    waveform2's Avatar
    * J e d i *
    Oct 2004
    Scotland
    435
    MY boot dosent have any of what you guys have i will take a pic later on and let you see.
    Derek
    Feb 2003
    739
    Jeff facelift boots are different.
    Derek if you have the cable it will be tucked behind the N/S suspension turret carpet.
    CraigM's Avatar
    Apr 2004
    Scotland, UK
    98
    [ QUOTE ]
    jdp1962 said:
    [ QUOTE ]
    [/ QUOTE ]
    Sorry I sent you in the wrong direction, Derek. Hope you find the lead, OK.
    [/ QUOTE ]
    My pic was wrong as well, didn't know there were that many different boot interiors! - at least we pointed him in the right area...
    Feb 2003
    739
    Craig your boost is the same as Dereks, it's just you have the factory fitted changer.
    Jun 2003
    World of my own
    9,813
    You can use Panasonic DP9060/61 which is essentially exactly the same as the OEM Audi changer, but you will need a cable adapter that plugs into the 10 pin connector and maps the pins to the Panasonic changer. Easier really to get an Audi one on ebay (about 120).
    A wide range of adapters are available from www.icd.ltd.com
    20-40 though, so not cheap.
    waveform2's Avatar
    * J e d i *
    Oct 2004
    Scotland
    435
    Andy,
    Pic of the Cable :
    Jun 2003
    World of my own
    9,813
    Hi Derek, that's the standard 13 pin plug, 3 pins are unused on all of them, so any 13 pin Audi changer will work.
    waveform2's Avatar
    * J e d i *
    Oct 2004
    Scotland
    435
    Excellent cheers Andy, Should be a bit easier to get one at a half decent price [img]/ubbthreads/images/graemlins/grin.gif[/img]
    johnyj's Avatar
    Jun 2004
    253
    i have a audi 6 disc from my 99 a4ts if you want it
    offers around 80 quid postage i would get a quote.
    pm me if you do
  28. #27
    waveform2's Avatar
    * J e d i *
    Oct 2004
    Scotland
    435
    [ QUOTE ]
    pm me if you do
    [/ QUOTE ]
    PM Sent [img]/ubbthreads/images/graemlins/beerchug.gif[/img] [img]/ubbthreads/images/graemlins/beerchug.gif[/img] [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
