Badger5EM Tuning
Results 1 to 11 of 11
    2,168
    1996 A4 1.8T Ebay bargin
    Last year I picked up a 1996 A4 FWD 1.8T in laser red, it has just over 110K on the clock and it was advertised on ebay for Ł499 buy it now. I had the intension of breaking the car as I wanted to strip it for the panels & other items to repair my 1996 A4.
    When I collected the car it had one day left on the MOT and the clutch was just about destroyed, so made for an intresting 50 mile drive back home, before driving the car back I ran vag-com on the car which reported the temp sensor & lambda sensors as the only electronic errors, as the last thing I wanted was to be left on the side of the road with a fecked Audi. So after a couple of weeks thinking what to do with the car I decided not to strip the car but restore it.
    The faults on the car were as follows
    Clutch was almost non existent
    Wipers only worked on full
    Shocks were damaged (Due to cr@p lowering springs)
    Coolant sensor was faulty
    Lambda sensor was faulty
    Interior was beyond grubby (Must have been used as a kids playground)
    Hole in the driver’s seat
    Steering wheel looked more like a sponge
    ABS kicks in just before the car stops
    Oil colour was jet black
    Coolant was nonexistent and was just brown (rust) water
    Lacquer is pealing from the bonnet
    Chavy boot spoiler which cover up the centre brake light
    Bulb on the instrument cluster out
    So over the last 6 months the following work has been done on the car
    New Bosch lambda sensor Ł80
    New Audi Temp sensor Ł15
    Boot lid from a scrap yard Ł20 in laser red
    Luk clutch inc thrust bearing Ł90
    3x oil & filter changes Ł40
    Coolant flushed about 6-8 times and expansion tank replaced Ł20
    Wiper stalk for scrap yard Ł10
    Passenger side seat Ł25
    Leather steering wheel from ebay Ł30
    Instrument cluster bulb Ł1
    Leather gear gaiter Ł18
    And final god knows how many hours @ 0.01p per hour with my labour rate.
    The biggest time consuming Jobs was the clutch (never replaced one before) then cleaning the interior, and finally stripping down the passenger seat which I got from the scrap yard which was in very good condition, and just used the covers & padding to rebuild the driver’s seat.
    I used about 80 litres of water in the vax to clean the rear passenger seat & carpet, but they have come up clean. I’ve still got to fully PC the car but the body work (expect the bonnet) is in good condition.
    The engine currently is free of faults and is running nice and smoothly, when the old clutch was removed the flywheel was found to be in very good condition, so did not need replacing as a new one would have push the cost of this car way over the budget I put aside to fix it up.
    The car went in for an Mot last week, and passed to my amazement with the following advisories
    Nearside Front anti-roll bar has slight play on ball joint [2.4.G.3]
    Front Exhaust has part of the system slightly deteriorated [7.1.1a]
    All brake discs slightly pitted
    The front part of the exhaust does need to be replace so on the lookout for a replacement unit, the brake discs have now cleaned up very well as the car had been sitting for 6 months and only drove about 6 miles to the MOT garage so still had a fair bit of surface rust.
    I’ll get some pictures of the car up tomorrow, but I am interested on how much the car is worth I was hoping to get just over the Ł1000 mark, once my other car has been restored (6-8 moths time). Once sold I will be on the lookout for an S2 Coupe
    I'll put some pictures tomorrow.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,374
    I have a downpipe here from an AJL (1.8T quattro) Its a bit shorter than the AEB one, but i'm sure that with another sleeve clamp you could cut your existing pipe off just after the flexi and join it into the AJL pipe...
    drop me a PM if your interested!
    1997 S4 - PPC ÂŁ999 Challenge Track Car Build
    TD5 Land Rover Defender build
    2,168
    that sounds good, is the pipe the same size?
    Will send you a PM.
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    interesting.. look forward to come pics well done on the MOT
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    2,168
    Cheers, have to say a big thanks to Geeman, as without his bargain shocks & springs there is not a chance in hell the car would have passed
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    LOL - You can't accredit the MOT pass to just me! You've worked your ass off to get it sorted! Well done!
    S2 Coupe... good choice. I've had a '96 2.0E and a '96 2.6E coupe in my time... both awesome vehicles.
    S2 was what I really wanted, but I was a lot younger and insurance was a lot higher back then!
    NEW 6 cylinder 40mm front springs - ÂŁ40
    PM me for more info
    2,168
    I've also had a 2.6E, got it off a mate as he was going away for a year traveling, however he ended up running out of cash and came back a few months early so did another deal to buy the car back off me. From looking around there are not many S2 kicking around at the moment, I hope that changes around the end of the year.
    Dec 2008
    48
    How did the clutch change go, did you hit any major snags , any good pointers you can share (links to a good guide)...
    2,168
    Well as show in the picture we had a ramp to lift the car which made the job a dam sight easier. I don't think I would have been able to do the job if it was on axle stands.
    Getting to some of the bolts was a right PITA, and it took me about 2 days to do the hole job. The only mistake I made was not fitting the slave cylinder before putting the gearbox back in. As know matter how hard you push on the thing it would not go in, so ended up removing th gear box again and fitting the slave cylinder. Another thing I found is by yourself some allen keys which you won't mind cutting down.
    A few pictures below to show the car on the ramp, and the support I made to help remove the gear box.
    Dec 2008
    48
    Ta La...Very helpfull
    "Stick a V8 in it!"
    15,374
    Personally if i was doing the clutch without a ramp, i'd pull the engine.
    At least that way your working above the car, with a crane, rather than humfing around underneath.
