AH FabricationsVolks Autos
    dans3.0's Avatar
    Apr 2007
    53
    T SPORT STALLING PROBLEM
    Hi all,
    Just popped over from the B6 side to ask some advice for my son
    He has an 1998 1.8T Sport Auto and just recently it has just started to stall immediatelly after start up, not every time but now and again.
    Any ideas what could cause this
    Dan
    A4 CABRIOLET 3.0 SPORT MULTITRONIC loaded
    phoenixv6quattro's Avatar
    staylowmovefast
    Sep 2009
    wycombe
    1,398
    Hello mate, there a literally 20+ threads about the illustrious stalling problem on this forum...Do a search and you will find a shed load! It could be a number of things, immob , TB , N80, wiring (Geemans recent prob), split breather pipes, clogged breather pipes etc etc etc...........
    IT COULD ALWAYS BE WORSE SO KEEP ON SMILING
    2,169
    As stated above, do you have or know anyone with vag-com, also does the immob light come on after it stalls?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,377
    immo is the first thing to look at, it will usually mean the immo light flashes after it stalls though.
    TD5 Land Rover Defender build
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Wiring was a problem on mine. The immediate stalling happened on mine after I'd sorted the wiring out though... and it was the actual connectors themselves not having a good solid grab on the MAF terminals. Closed them up tighter and now it's fine.
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
    dans3.0's Avatar
    Apr 2007
    53
    Thanks all,
    He says the Immo light dosn't come on, he's going to clean maf etc check wiring and go from there,
    its not done it since so will have to wait n see.
    Dan
