Monster MotorsportVolks Autos
Results 1 to 15 of 15
    Missed A Gear
    Aug 2009
    Aberdeenshire
    43
    Water pipe failure...Potential disaster, Averted
    After yesterdays escapades I thought Id write up what has happened to make s4 owners aware of this possible problem.
    When doing a routine oil change I noticed a steal pipe running from the oil cooler weep coolant. On further inspection it seems that the metal pipe has corroded through to a hole. Realising that the pipe would have to be taken out and replaced I proceeded to turn the pipe in every possible orientation to try and slide the pipe out from between the front engine mount and block. However this was not possible without removing the front end and taking off the front engine mount. I made the decision to cut the pipe in the middle, slide it out and then fabricate a new pipe. You can see from the pics below that the pipe was very close to complete failure in several places, which would have resulted in very warm oil and possible engine failure.
    pipe removed and cut in half
    close up of corrosion
    pipe was cleaned up to find many small holes and thin pipe walls
    new pipe made up from copper pipe and yorkshire fittings
    fabricated pipe in new location under engine mount
    it would my advice to check this component during a timing belt service interval as change out at this time would be straight forward.
    Sep 2009
    Essex
    2,366
    does your car have its engine under tray still?
    Missed A Gear
    Aug 2009
    Aberdeenshire
    43
    yes. but it had to be removed during oil changing and pipe replacement. i will keep it removed untill i am sure there are no more leaks.
    Sep 2009
    Essex
    2,366
    thats really interesting then. id have thought maybe stone chip damage could have started the corrosion on that pipe. maybe something was spilt all down there in the past and started the corrosion.
    bullet successfully dodged
    Missed A Gear
    Aug 2009
    Aberdeenshire
    43
    no the standard pipe is located further up out of the way. if only audi's leaked more oil then this would probably never of happened. l0l
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,934
    I'm not sure about using copper pipe on an engine...
    Copper tends to work harden quite easily and would then fracture...
    TD5 Land Rover Defender build
    phoenixv6quattro's Avatar
    staylowmovefast
    Sep 2009
    wycombe
    1,391
    I can vouch for that, fabricated some copper pipe for my old 21 turbo. Lasted under 3 months before pissing everywhere!
    !!BINGO BONGO!!
    "Stick a V8 in it!"
    14,934
    Ye, the pipes only about 20 or 30quid new from audi by the looks of it...
    staylowmovefast
    Sep 2009
    wycombe
    1,391
    Nice write up though buddy. Its good when someone takes the time out to post pics etc to make other owners aware of the potential problem, and gives them the heads up on how to fix it! FAIR PLAY.
    !!BINGO BONGO!!
    Missed A Gear
    Aug 2009
    Aberdeenshire
    43
    yes twenty to thirty quid is cheap but it would take hours to remove the front end to get the replacement pipe in place. which was not a job i was looking forward to do to replace one pipe. the copper should be fine i made a bracket to hold the copper from moving and fracturing.
    "Stick a V8 in it!"
    14,934
    keep an eye on it...
    staylowmovefast
    Sep 2009
    wycombe
    1,391
    A very alert and watchfull eye.......
    !!BINGO BONGO!!
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    I had to have this very pipe replaced on my A8 2.8 as it was losing water through the same part!
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
    heymynameismark's Avatar
    Cool beans.
    Sep 2009
    Aberdeen/Dundee
    126
    Good write up that! Well done. As said, keep an eye on it though!
    Would my 2.6 quattro have the same pipe as I'm loosing water and can't see where from ?
