Volks AutosMonster Motorsport
Results 1 to 15 of 15
    Bushen's Avatar
    Driving with style
    Oct 2007
    Taunton
    52
    Losing water.....HELPP!!!!
    Hi guys
    my audi a4 1.8t is now losing quite alot of water and after about 50 minutes of cruising i have to fill the water back up. My car however is not overheating. It was fine until my friend cleaned out the radiator and since then my water warning light keeps coming up.....Any suggestion on what it could be?? My worries are that it could be my headgasket!?!? Cheers
    1,868
    If there is no oil in the water, then it's unlikely to be the head gasket. I guess I would be looking for leak's around the radiator hoses, or the drain plug is not secure.
    jamie226bhp's Avatar
    Aug 2009
    456
    small leak in rad perhaps that somone used radweld or similar on and the flush through has made it come back
    Bushen's Avatar
    Driving with style
    Oct 2007
    Taunton
    52
    Well when my friend cleaned the rad out.....it was full of brown crap basically...once we had cleaned the rad out you could see oil in the brown crap.
    1,868
    What about oil in the expansion tank? It should be visible on there.
    The brown crap will mostly be rust, someone has not put enough coolant in the system.
    Bushen's Avatar
    Driving with style
    Oct 2007
    Taunton
    52
    And the expansion tank would be?? sorry im not very mechanically minded and only know the very basics about cars.
    1,868
    it's the tank where you add the water to the system if you stick your finger in there and pull it out does the water feel oily?
    Bushen's Avatar
    Driving with style
    Oct 2007
    Taunton
    52
    Yeh put my finger in it and its like a brown cream?!?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    Sounds like the headgasket, or perhaps the oil cooler then mate
    TD5 Land Rover Defender build
    Bushen's Avatar
    Driving with style
    Oct 2007
    Taunton
    52
    But wouldnt it be water in the oil instead of oil in the water....cos theres no water in the oil.....also its not miss-firing and the exhaust is not kicking white smoke and its not overheating??? its just really confusing!?!? lol
    "Stick a V8 in it!"
    14,900
    oil pressure is much higher than the coolant pressure, so it could just blow thru in one direction?
    Might be worth try another oil cooler before condemning the gasket?
    Jul 2007
    765
    Have you checkedthe tank for cracks?We had this on a 2.5 TDI recently and They are only 12 to replace and I was told that they are a regular seller .THe tank can be removed easily without discnnecting any pipes and its worth a look
    Bushen's Avatar
    Driving with style
    Oct 2007
    Taunton
    52
    I dont think its head gasket anymore....spoke to a mechanic and he said if it aint miss firing and the oil colour is fine...which it is then its not head gasket...gonna give it too him on thursday to check it out anyways.
    "Stick a V8 in it!"
    14,900
    You have oil in the coolant. The only place it could come from is the head gasket or the oil cooler.
    Bushen's Avatar
    Driving with style
    Oct 2007
    Taunton
    52
    What about anti freeze...does that give off the same effect if mixed with water..like oil does?? that rainbow coloured mixture?
