EM TuningMonster Motorsport
Thread: Dip stick stuck
    bad-vw-boy's Avatar
    Dec 2007
    73
    Dip stick stuck
    Just tried to check the oil and the dipstick got stuck managed to put it back but being fairly new to these cars not sure if there is a special way to remove them, also what oil do you guys recommend?
    1,873
    When I replace the dipstick on my 1.8 T as the last owner somehow damaged the last one, I end up using sanding the top of the dipstick with a bit of wet & dry to make it easier to remove.
    bad-vw-boy's Avatar
    Dec 2007
    73
    Re: Dip stick stuck
    I can't even remove my dip stick it seems to get stuck at the end its a v6 s4 engine if that helps
    1999 S4 B5 Avant........feel the power...
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,691
    They are just a bit tight. Should come out easily enough given enough pressure.
    Mo power, mo problems
