Just tried to check the oil and the dipstick got stuck managed to put it back but being fairly new to these cars not sure if there is a special way to remove them, also what oil do you guys recommend?
When I replace the dipstick on my 1.8 T as the last owner somehow damaged the last one, I end up using sanding the top of the dipstick with a bit of wet & dry to make it easier to remove.
