Volks AutosChris Nott
Results 1 to 11 of 11
    bad-vw-boy's Avatar
    Dec 2007
    73
    Air bag light on
    hi , i have just picked a S4 and the airbag light has come on , on the dash, is this something i can fix or do i need to go to Audi.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,905
    You need to get yourself vagcom. That way you can find out why its come on and once fixed you can clear the fault code.
    Its most likely the connector under one of the seats for the side airbag.
    Genuine Vagcom is around 200-250ish, however if thats too much you can buy a basic lead from ebay for about a tenner, which you can use with the trial version of the software and do the basics, such as reading and clearing codes.
    TD5 Land Rover Defender build
    bad-vw-boy's Avatar
    Dec 2007
    73
    has anyone in the guildford area got a vagcom??
    951
    951's Avatar
    Feb 2007
    North east
    493
    Mine did this and it was the connection under the drivers seat as already suggested.
    A4 Avant 1.8T Sport (183 bhp).
    bad-vw-boy's Avatar
    Dec 2007
    73
    Re: Air bag light on
    I found a small connector under the seat not great connection if I am to be honest If you fiddle with it ,it falls off so it might be that will the light go off imediatly ?
    1999 S4 B5 Avant........feel the power...
    "Stick a V8 in it!"
    14,905
    Once on, the light will stay on until its cleared with vagcom. Even if the fault has been rectified.
    the matrix is comin
    Jan 2009
    ramsgate
    147
    i've got it showing on mine. but we have worked out its the clockwork spring in the steering wheel
    built in germany caressed and loved in england.
    Mar 2010
    MARGATE, KENT
    35
    Mine came on three days ago... after using a service reset tool I purchased on ebay.... didn't clear service 2 either!
    "Stick a V8 in it!"
    14,905
    Why buy a silly service reset tool, when you can buy a generic vagcom lead for a tenner?
    Mar 2010
    MARGATE, KENT
    35
    Didn't know you could.... You live and you learn though!
    Any ideas if that couldve been the problem?
    "Stick a V8 in it!"
    14,905
    Possibly. I can only suggest getting a vagcom lead and finding out what is actually wrong with the controller.
