Chris NottMonster Motorsport
    40
    Possible Boost leak?
    Since hooking the boost gauge up I haven’t really paid to much attention to boost levels whilst driving (waiting for the right holder from Canada). On the way to work this morning I monitored the levels and it seems to be seeing an initial 16psi before dropping back to 12-13psi. Is this considered normal or would this suggest a possible boost leak? The car has been remapped previous to me buying the car its a '00 1.8T DBW which had a replacement turbo fitted a couple of years ago but looks like a K03-005 and not a K03-029. Bar the remap and a 710N the car is standard.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    I think its pretty normal for a slight overshoot, its just the way the N75 control works.
    1997 S4 - PPC ÂŁ999 Challenge Track Car Build
    TD5 Land Rover Defender build
    40
    Thought it might be the norm cheers aragorn. Will be looking to fit a N75j and new TIP soon but are the silicone TIP's really worth it??
    "Stick a V8 in it!"
    15,388
    i wouldnt bother with the J valve, it usually causes an even larger spike, and can often cause fault codes etc.
    silicone TIP helps stop it collapsing in under full power;.
