Monster MotorsportChris Nott
Results 1 to 8 of 8
    ButcherV6's Avatar
    Live Fast Die Smiling
    WestYorkshire
    24
    Torque setting for cam cover bolts?
    Hi all, can anyone tell be the torque settings for the cam (rocker) cover bolts on my 98 2.4 V6? Iv got a very slight oil leak so I'm going to remove and re seal with some instant gasket just need the torque settings. Thanks.
    Sep 2009
    Essex
    2,366
    elsa says you specifically need liquid gasket on the corners where the cam cover humps up to clear the cams.
    cyl head cover bolts are 10nm (i guess theyre M6 bolts?)
    if so 10nm is spot on
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    ye, its barely more than finger tight.
    I managed to strip one of mine after changing the rocker gasket, doing them up hand tight with a 3/8 drive ratchet...
    TD5 Land Rover Defender build
    Sep 2009
    Essex
    2,366
    id definately tackle that with a torque wrench, do it in the usual axial pattern blah blah blah. new gasket and some liquid gasket on the humps and youll be done.
    "Stick a V8 in it!"
    15,389
    my torque wrench starts at 30nm, so it wasnt any use!
    I should probably invest in a little one.
    Sep 2009
    Essex
    2,366
    i have a nice draper one, 10nm to 70nm then a big 1/2 drive one. 30nm (i think) to beyond 200nm for bigger bolts, suspension bits etc
    audinary's Avatar
    Aug 2008
    Frinton-On-Sea
    646
    I had the same scenario with my cam-belt cover, no torque figure given in the Haynes manual (bonfire fuel) so I did them using my built-in "that feels about right" human torque wrench. Well, my girlfriend does call me a spanner...
    '98 Santorin Blue 1.8t Sport
    Sep 2009
    Essex
    2,366
    tbh most bolts have figures stamped on them giving the tensile strength of the bolt. using that and the diameter of the thread you can use charts to find out the torque setting
    example. on the golf, the haynes etc all say the sump bolts are 25nm.... theyre M6 and people strip the threads left right and centre when in reality, M6 wants 10NM. used that and its been spot on since
