EM TuningAH Fabrications
Results 1 to 8 of 8
Thread: ABS Light
    colinurquhart's Avatar
    Jun 2009
    200
    ABS Light
    Hi guys, just changed the rear discs and pads on my '97 1.8 avant everything went ok, lost some brake fluid from the bleed nipple when pushing the piston back but thats normal. Straight away my ABS light came on so I just assumed it was because of low fluid. The following day changed my front pads and topped up my brake fluid from the loss of the front and rears getting down. I haven't bled them yet but my brakes feel amazing, the best they've been since I've had the car yet my ABS light is still on, any ideas? Thanks
    heymynameismark's Avatar
    Cool beans.
    Sep 2009
    Aberdeen/Dundee
    126
    You may have damaged your rear ABS sensor. They're very brittle and delicate when they get on a bit. Could you have disturbed one or the other when changing your brakes over?
    It might also be worth checking on VAGCOM for location specifics if you can!
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,355
    When you changed the discs on the rear did you get discs with the ABS rings fitted or did you swap them drom the old discs?
    Jun 2009
    200
    I don't remeber seeing any ABS sensors on the back thats whats confused me, I don't think I even saw any wires?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,904
    the sensor just looks like a silver mound sticking out of the backplate.
    Its the reluctors that are probably the issue. They are pressed onto the rear of the rear brake disk, and often dont come with new disks, so unless you transferred the reluctor over, they'll be missing.
    We had ours like that for a few weeks. ABS would only come on after you started moving though if its that.
    TD5 Land Rover Defender build
    Jun 2009
    200
    No I didn't transfer anything over or even notice anything. Will my ABS still work ok and whats the best solution to fix it, thanks
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,065
    losing brake fluid doing a pad change isnt normal, did you open bleed nipple? you should just open reservoir to release pressure when you rewind caliper then you should have too much fluid when your done
    did you bin old discs, if so you'll have to buy new abs rings and fit them
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    "Stick a V8 in it!"
    14,904
    The ABS will have disabled itself if the warning is on the dash.
    Can you confirm that the warning only appears after you start moving?
    If it comes up as soon as you start the car its not the reluctor. If it comes up after you start moving, then it most likely is the reluctor. It sits round the inside of the "hub" section, where you fit the inner bearing.
