Sky InsuranceAH Fabrications
Results 1 to 20 of 20
    S4twiggy's Avatar
    Fully Certified Detailer!!
    Feb 2009
    South Wales
    1,811
    removing service light
    next week i shall be doing a service on my car myself as funds are low. im just wondering how i remove the service reminder that comes up on the DIS, is it done with vagcom? do i need the rosstech vagcom to do it as i only have the demo version i think?
    Aug 2009
    middlesbrough
    92
    yeah id like to know this too, i found some instructions on the net to remove the service reminder but never worked, pull and hold speedo reset and turn key push this and that, what a load of tosh
    phoenixv6quattro's Avatar
    staylowmovefast
    Sep 2009
    wycombe
    1,391
    Me too, as I have just changed the oil and my oil service light has just started flashing!
    !!BINGO BONGO!!
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,065
    the push this pull that instructions should work on 98ish on cars, but i always end up just altering clock when i try from memory
    vagcom
    http://www.ross-tech.com/vag-com/cars/audi_sri.html
    you can adjust length of time aswell, my oil light is now set at 5k so its when i want to change oil not when audi say it should be done
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    20
    Just to confirm though, do you need the full version of VAGCOM to do this or can it be done in the 'demo' version?
    Jun 2003
    World of my own
    9,813
    Yes the demo version will just scan and show the results, it doesn't allow you to actually do anything.
    The push pull technique definately works on B6 A4's but definately not on my 97 plate.
    Alex Turner
    S4twiggy's Avatar
    Feb 2009
    South Wales
    1,811
    i shall be getting rosstech vagcom soon then, just wish i had someone to teach me the ropes on it.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,355
    Grant, you should have mentioned it to Rob, he could have done it on VAGcom . Any facelift car should be able to be reset via the dash knobs. My 98 was dash resettable.
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    I can't do mine the way it tells you in the book. Not sure if it's because mine is facelift with a digi clock?
    Apr 2004
    12,355
    Hmmm I am sure there is a date from which service lights/displays can be end user reset.
    Mine reset via the knobs, it must be because i have a half baked facelift car,lol
    May 2008
    perth
    1,197
    Mine is only on a v plate so you would think it would be more likley to have the analouge clock. I need to get a vag com lead as it flashes up service every time I start it now.
    staylowmovefast
    Sep 2009
    wycombe
    1,391
    So how do you reset it manually via the buttons/knobs? Mine is a late 98 so I would like to give it a go, but don't know how? I havn't got the manual (if it explains it in there?)......
    !!BINGO BONGO!!
    Apr 2004
    12,355
    staylowmovefast
    Sep 2009
    wycombe
    1,391
    Thankyou you very much my good man!-Will try tomorrow on my pre-facelift and report......
    !!BINGO BONGO!!
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,065
    Quote Originally Posted by Byzan A4 View Post
    i reckon it would be at the same point they switched to immo 2 and got new clusters post 98ish
    not sure about the later digi clock ones though
    kev
    90 eunos roadster
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,904
    immo2 didnt happen until mid 99
    97-99 cars still have immo1, its just integrated into the dash cluster rather than a seperate box.
    TD5 Land Rover Defender build
    staylowmovefast
    Sep 2009
    wycombe
    1,391
    IT WORKED!!! And as mentioned mine is a late 1998.....Thanks again fellas!
    !!BINGO BONGO!!
    S4twiggy's Avatar
    Feb 2009
    South Wales
    1,811
    forgot to mention it mate, only realised when i got home and saw my service stuff ready for me to do it on the weekend.
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,065
    think your wrong on this one although my point is 'if your immo is built into cluster then you can reset service reminders'
    all the pre 98 cars with seperate box ive coded have needed a new write once only megamos 13 transponder
    the post 98 ones use a crypto 48 transponder and are reuseable so must be a different immobiliser?
    kev
    90 eunos roadster
    "Stick a V8 in it!"
    14,904
    Ye, they changed to variable code transponders, but its still immo1.
    The details are in ETKA, it mentioned "fixed code" and "variable code" transponders under the immo1 section, and says immo2 comes in mid 99 and immo3 comes in mid 00.
