Badger5Volks Autos
Thread: radio question
    rob v6's Avatar
    Learning the VAG way
    Oct 2009
    Dudley
    161
    radio question
    Just wondering will a symphony 2 with built in 6 cd changer fit in a a4 b5 that has a symphony radio already fitted?
    2.4 V6 SE Avant
    2,165
    I take it your talking about the B6/B7 symphony unit, if so then you would need a can-bus converter (if your car does not have infotainment can-bus, at the instrument cluster) there would also be gaps around the centre console.
    Also the rear speaker would need to be driven by an amp, if they are not already.
    rob v6's Avatar
    Oct 2009
    Dudley
    161
    ok thanks mate so it would work with a bit of work
    2.4 V6 SE Avant
    2,165
    Yes, with a bit of work. I fitted RNS-E into a single DIN B5, so anything is possible. What MY is your B5?
