EM TuningSky Insurance
Results 1 to 10 of 10
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Theoretically speaking...
    ... you could install the 4.2 V8 / S8 engine, coupled to the Passat Tdi 130 6-speed 'box, with V6 driveshafts and hubs... and you're away?
    Just day dreaming about possibilities...
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,354
    Yup.
    Could even bolt it direct to your box iff necc.
    If going V8, i would deffo use a quattro for a base.
    At least until Paul1982 gets his back to let us know how it drives 2WD
    Aug 2009
    Dorset, UK
    171
    could a TDI 130 box handle the bhp & Torque ????
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    After what you said about motorway usage, the 6-speed box seems quite appealing.
    Will see what Paul says when he gets his back on the road then...
    PM me for more info
    Apr 2004
    12,354
    Quote Originally Posted by Nitro View Post
    Easily, the 6 speed is an 01E box the same style as fitted to an S4 etc. Oh and the V8 probably makes less torque that a decently tuned diesel tbh.
    It's torque that kills boxes not power, there ars some big power 1.8ts and 2.0l running on std 016 transmissions in the US
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    Ye you wouldnt even need the 6speed.
    The stock 5speed would work just fine.
    The V8 makes around 400nm of torque.
    As mark says, thats basically exactly what pauls had done, although hes kept the 5speed and the original hubs etc afaik.
    TD5 Land Rover Defender build
    slepy's Avatar
    No Audi but still here
    Sep 2009
    Sheffield
    910
    That is what I'm gonna do If I finally get A4Q.
    Was checking what kind of speed on each gear you get from 5 and 6 speed gearboxes.
    Difference is small and less shifting with 5 speed. Economy will not be an issue cause it's not gonna be daily.
    Still not sure if I should get 2.8 or 2.6. Facelift 2.8 would be a dream but cost is much higher.
    2007 Honda Civic Type R daily. Soon for sale
    1999 Audi A4 1.8TQS - track car project
    Jul 2007
    London
    3,074
    I would use a 2.5 v6 tdi gearbox and shafts as the 5 speed gearbox is not strong enough. The 01E fitted to the 180Bhp diesel engine will take 500Bhp and 600Nm all day long. Its the clutch and flywheel thats the weakest link. Make shure you go quattro as it will help getting the power on the road + wont snap the driveshafts on every take-off !
    FOR SALE:
    slepy's Avatar
    Sep 2009
    Sheffield
    910
    Guy in US did his swap with 5 speed (from 1.8T) gearbox with RS4 clutch
    and looks like it works fine.
    "Stick a V8 in it!"
    14,900
    the 5speed is plenty strong.
