AH FabricationsVolks Autos
Results 1 to 12 of 12
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    S4 ENGINE AND TRANNY WEIGHT ??
    been searching about for the answer so i can get a crane ordered just want to check a 1 ton one is ok for the job?
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    jcb
    Sep 2005
    uk
    4,077
    well under 1 ton
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,325
    The engine is probably 210kgs or so
    The box is maybe 50-75kgs?
    TD5 Land Rover Defender build
    jcb
    Sep 2005
    uk
    4,077
    Well I know first hand that a 1.8t block, head, flywheel, clutch and engine stand adapter is about 0.1kg short of "too ****ing heavy"!!!
    nearly burst a testicle getting it on the engine stand!
    I was feeling young and ambitious at the time!
    2,153
    Quote Originally Posted by jcb View Post
    nearly burst a testicle getting it on the engine stand!!
    Fantastic
    I was also looking for a crane to remove a 1.8 engine so if the S4 is under then ton then it should be fine for the 1.8...
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,512
    The box is deffo heavier than a 5 speed by about 20KG.
    And to move an s4 lump arond a garage floor took 4 of us,lol
    You could cut the whole front off the car and lift it for under a ton. I am sure the crane we hired was a ton and it p!ssed it
    jcb
    Sep 2005
    uk
    4,077
    not many engine/boxes break the 350-400kg mark
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    I bet a few yank boat anchor v8's will.
    jcb
    Sep 2005
    uk
    4,077
    Quote Originally Posted by ian52 View Post
    actually a lot of the yank boat anchors were much further ahead in using aluminium blocks/heads. its one of the reasons Rover bought the rights the Buick V8 that filled the Land Rovers, Range Rovers, SD1's, MGBs, Triumph Stags, TVR's etc etc.
    they may be push rod tastic old school crap now but remarkably light....
    May 2008
    perth
    1,197
    Pitty they dont make the cars lighter then.
    jcb
    Sep 2005
    uk
    4,077
    true...pity they don't make some yanks lighter too!
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    Okee Dokee 1 ton crane it is then , i shall probably be renting this out after ive bought it too
