Monster MotorsportBadger5
Results 1 to 11 of 11
    Audijarvis's Avatar
    Manchester
    143
    1.6 95 A4 Speaker wiring diagram
    Won a JVC head and disc changer on fleabay and would like to know the colours of the wires for front and rear speakers
    The front speakers work ok but I have no sound from the rear speakers (I know an amp would be the best option but no funds at present)
    Anybody have a diagram, link or just the colours to help me out please
    Jarvis
    Jun 2003
    World of my own
    9,813
    The rears run off a tiny amp bolte to the left rear deck speaker so there are no speaker wires at the HU for the rears, you need to run new cable. You can buy an adapter to link the rear RCA's to the tiny amp but really you should bypass it as the JVC will have far better quality and at least twice the power.
    Alex Turner
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,088
    ^ What he said. I had grief whe I used a converter block for the factory amp. Sounded crap and used to whistle slightly at low volume. Don't have any of the factory system left in the car now (although it can all be refitted)
    Life begins at 140mph
    www.passionford.com
    2,175
    Strange neither of my 1996 B5's have an AMP fitted for the rears, all speaker wiring goes direct to the HU. Wonder what option was specified to get the rear AMP?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,384
    B5: were they avants?
    I think the amped rears are only on saloons, ours certainly jsut goes directly to the head unit.
    TD5 Land Rover Defender build
    Audijarvis's Avatar
    Manchester
    143
    Thanks for the replies
    Think I'm going to fit the HU and changer at the weekend with the wiring as it is (fronts only) and concerntate on saving for my amp and some decent speakers
    2,175
    No they are both saloons, and both Manufactured in 1996.
    Audijarvis's Avatar
    Manchester
    143
    Problems solved,all speakers working and head unit and changer do exactly what it says's on the tin
    Firstly the rear speakers don't have amps, well not on the 95 1.6 b5 saloon
    The reason I couldn't get them to work was that I had brought the wrong ISO connectors, the PC9-401 is for later models. with the rear speakers amplified
    I went to an audio specialists in Leicester and one of the technicians took one look and pointed me in the right direction
    Took a permanent live from the hazard switch and stuck with the other switched live from the rear screen heater switch and Bobs your uncle
    I'll post the new ISO's part number tomorrow
    Thanks again everyone
    "Stick a V8 in it!"
    15,384
    Mate those power feeds are pikey as hell...
    The stereo loom already has a permenant live, and the switched live should come from a suitably fused feed.
    Audijarvis's Avatar
    Manchester
    143
    The stereo looms live wasn't (probably why the previous owner hacked into the rear screens switched live)
    Both lives have an amp rating of at least 10amps (the HU has a 10 amp fuse, so that should be protected) so should be safe for the current the HU draws
    Neither the hazards or the rear screen heater need to be on constant so the circuit shouldn't be over loaded, and the friend that fitted it is a time served and qualified electrician so I'll trust him to not set my car on fire
    "Stick a V8 in it!"
    15,384
    Its more that the wiring from your splice to the stereo is fused at 30A (in the case of the heated screen) and wont be rated to anything near that. Fuses arent there to protect the stuff at the end of them, they're there to protect the wires.
    If your mate is a (good) time served spark, then he'd never consider taking an unfused spur from a domestic ring main in 1.0mm^2 cable.... yet thats no different to what you've described he's done here.
    Doesnt neccesarily mean its going to blow up, but its still pikey.
