Volks AutosChris Nott
Results 1 to 8 of 8
Thread: oil change
    149
    oil change
    can u change the oil on a4 b5 avant with out axel stands due to the placki cover or is it an arse never removed it b4 so ??????????????????? cheers
    1,873
    It can be removed with out axle stands, but you may need a jack to get the rear screws out. Even more so if it's been lowered...
    149
    not lowered yet not sure bout climbing under jacked up are they just screws or bolts is the filter near sump plug ?
    1,873
    They are removed using a large flat blade screw driver, they take around 2 turns if that to remove. If you don't trust the jack shove a alloy wheel under the car, the the jack fails it will land on the alloy...
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    Mine is on normal sport ride height, and i usually manage an oil change without lifting the car, you just need a shallow enough drain pan.
    TD5 Land Rover Defender build
    Sep 2009
    Essex
    2,366
    just drive the car up onto a couple blocks of wood
    Jul 2007
    London
    3,074
    Or buy a Pella oil extractor !!! Fits trough the dipstick tube and will suck the engine oil like a whore in need of crack ! Sorry for the analogy !
    FOR SALE:
    149
    how much are pella oil extractors my whore wont suck oil yet "SLAP" SORRY ? might just tryold way
