Sky InsuranceVolks Autos
    Oct 2004
    Alarm/ immobilser question
    I have a query with my alarm/ immobiliser. The other day I locked the car using the remote locking, and the little red light next to the door pop up did not come on, but the doors locked. Instead, after about 1 minute the hazard lights started flashing. I reopened the doors and tried to lock them again,. The same thing happened. I tried a few times and exactly the same occured. So, I got in the car shut the door, and the Driver information display said that my door was open, but it was firmly shut. Eventually after a bit of messing about I managed to lock the doors and set the alarm and immobiliser.
    Has anybody ever heard of this?? If so any idea on the problem.
    Other than this my Audi has been brilliant!! [img]/ubbthreads/images/graemlins/groovy.gif[/img]
    Regards,
    Milton Keynes UK
    248
    Re: Alarm/ immobilser question
    Sounds like you have a problem with the drivers door switch. The Alarm will not come on until the doors are locked and all doors are shut.
    The sensor button for the rear doors are located on the body, however there is no button for the front doors. The sensor is located in the door latch assembly, which meens you will have to remove the inside panel of the door to get access. Check the connections, otherwise it could be the microswitch is not alligned correctly. Might be easier to replace the assembly, it is fiddley but can be done within a hour.
    If you want a 2nd hand replacement, try the following contact -
    Overton Dismantlers
    Overton Garage Ltd
    off Dyce Drive
    Aberdeen
    Scotland AB21 0EQ
    Tel: 00.44.1224.722354
    Parts Fax: 00.44.1224.775451
    General Fax:00.44.1224.722457
    Email : sales@overtongarage.co.uk
    Regards,
    Jim.
