JMB RetrofitsSky Insurance
Results 1 to 15 of 15
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    bet no one can beat this mot failure sheet!
    as my new car came with nothing but a v5 i thought id check when mot ran out on the .gov website
    all i can say is wow it was allowed to leave testing station
    all the stuff in red ive already sorted and i was about to put it in for a test but i think ive got a bit more to do
    Reason(s) for refusal to issue CertificateAnti-lock braking system warning lamp indicates an ABS fault (3.4.1d)Nearside Windscreen wiper does not clear the windscreen effectively (8.2.2)Offside Windscreen wiper does not clear the windscreen effectively (8.2.2)Nearside Stop lamp not working (1.3.2a)Offside Front Lower leading/inner Suspension arm rubber bush deteriorated resulting in excessive movement (2.4.G.3)Nearside Front Lower trailing/inner Suspension arm rubber bush deteriorated resulting in excessive movement (2.4.G.3)Nearside Front Lower trailing Suspension arm has excessive play in a ball joint (2.4.G.3)Nearside Front Front constant velocity joint gaiter insecurely mounted to its housing (2.5.C.1a)Centre box joint Exhaust has a major leak of exhaust gases (7.1.2a)Nearside Rear Brake pad(s) less than 1.5 mm thick (3.5.1f)Offside Rear Brake pad(s) less than 1.5 mm thick (3.5.1f)Offside Front Tyre has a bulge, caused by separation or partial failure of its structure (4.1.C.1b)Nearside Front Tyre tread depth below requirements of 1.6mm (4.1.D.1)Nearside Rear Tyre tread depth below requirements of 1.6mm (4.1.D.1)Offside Rear Tyre tread depth below requirements of 1.6mm (4.1.D.1)Offside Front Wheel bolt(s) missing (4.2.1c)Offside Wheel bolt(s) missing (4.2.1c)Offside Front Upper leading/inner Suspension arm rubber bush deteriorated resulting in excessive movement (2.4.G.3)Offside Front Upper trailing/inner Suspension arm rubber bush deteriorated resulting in excessive movement (2.4.G.3)Nearside Front Lower leading Suspension arm has excessive play in a ball joint (2.4.G.3)Nearside Front trailing/inner Suspension arm rubber bush deteriorated resulting in excessive movement (2.4.G.3)Nearside Rear Brake disc(s) excessively pitted (3.5.1h)Offside Rear Brake disc(s) excessively pitted (3.5.1h)Nearside Rear Road wheel bead rim badly distorted (4.2.1a)Nearside Rear wheel bearing has excessive play (2.6.2)Nearside Front Front brake juddering severely (3.7.A.2b)Offside Front Front brake juddering severely (3.7.A.2b)Nearside Rear Rear brake juddering severely (3.7.A.5b)Offside Rear Rear brake juddering severely (3.7.A.5b)Front brakes imbalanced (3.7.A.2e)Advisory Notice issuedFront both Brake disc(s) slightly pitted (3.5.1h)Front bumper insecure
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    Jul 2008
    Birmingham
    629
    New tyres, pads and discs will fix most of that.
    I thought mine was bad... :P
    A4 1.8TQS
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    and a full set of front arms by the looks of it lol!
    TD5 Land Rover Defender build
    audinary's Avatar
    Aug 2008
    Frinton-On-Sea
    646
    Wheel bolts missing?
    Really?!?
    '98 Santorin Blue 1.8t Sport
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    Quote Originally Posted by voteforpedro View Post
    it came with 17" wolfrace voodoos which im going to refurb and use as winter wheels as i quite like them
    swapped all top arms, offside hub (threads for wheel bolts where knackered) rear discs and pads with bearings and 16" sport alloys and bolts from the avant im breaking while i swapped suspension
    also spent 2 days cleaning it, seats out and vax'd carpets + machine polished bodywork, its getting there
    kev
    90 eunos roadster
    rob v6's Avatar
    Learning the VAG way
    Oct 2009
    Dudley
    161
    That is one big list how the hell some people can leave a car to go like that
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    ive got loads of spares! already done all tops didnt think bottoms looked that bad, looks like i was wrong
    kev
    90 eunos roadster
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    Quote Originally Posted by audinary View Post
    Really?!?
    some missing some wouldnt go in due to knackered threads
    kev
    90 eunos roadster
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    Quote Originally Posted by rob v6 View Post
    think owner was retarded, driving it to the mot station he could of lost his license at 3 points a tyre
    when it came with leather interior from a later model, performance back box, bailey dump valve, k+n, koni coilovers 17" alloys etc youd think it would be a bit better looked after
    kev
    90 eunos roadster
    Aug 2009
    middlesbrough
    92
    mine failed on 5 things
    1- number plate non reflective
    2- number plate had no bs number
    3- number plate was the wrong font
    4- number plate had no makers name
    5-number plate had no postcode
    as you can tell i changed my number plate and it passed but what a piss take i thought
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    was that on a b5 or newer car? non of my cars plates have makers name/postcode
    kev
    90 eunos roadster
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    wow what a list, hope it was worth it?
    so can you see other cars mot report online with being the owner of the vehicle?
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    "Stick a V8 in it!"
    15,370
    you need the registration number, and some kinda reference from the v5, so basically you need to own the car.
    But if you have the docs, you can view all its previous MOT's, and see what its failed on or being given advisories on, since the computerisation thing happened.
    Aug 2009
    middlesbrough
    92
    it was on a b5 but the plates were the german look ones that were made of tin, took them off and they bent like a banana,so had to go in the bin
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,082
    I have a German plate on the front of mine and the last 2 MOT's a standard plate has been stuck over the top of the German one with 2 thin slivers of double sided tape. Just after the MOT it falls off and goes back in the boot until the next MOT. lol
    Life begins at 140mph
    www.passionford.com
