AH FabricationsVolks Autos
Results 1 to 11 of 11
    Oct 2009
    50
    2.8Q Fuel woes..
    Hello, I seem to have a very very thirsty car, put Ł10 in and im lucky if i see 20 miles out of it, have checked for leaks, seems to be the odd bit of vapour coming from the driver side but cant see any leaks, anyone had a similar problem? Also the car seems down on power, doesnt rev as clean as it should, how can i get it running nice again? Its on 121k just had a service too..
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    First and simplest, does the temp guage come up to 90 within a few miles and stay there?
    Secondly, these cars dont have "engine management" or "check engine" lights, so the ECU could very well have recorded a number of faults, it just wont show you what they are. You need to scan the car using vagcom or similar to find out whats happening. Copy vagcom leads are available on ebay for around a tenner, and they're enough to get you started.
    1997 S4 - PPC ÂŁ999 Challenge Track Car Build
    TD5 Land Rover Defender build
    mugglesquop's Avatar
    Dec 2009
    Cheltenham, UK
    65
    Quote Originally Posted by Padz View Post
    10.2 mpg (working on Ł1.12 a litre)... thats not good lol.
    can you get it hooked up to VAG-Com to check sensors?
    '97 A4 1.8TSport Avant
    phoenixv6quattro's Avatar
    staylowmovefast
    Sep 2009
    wycombe
    1,398
    Lambada sensor or MAF?
    Dec 2009
    Cheltenham, UK
    65
    Quote Originally Posted by phoenixv6quattro View Post
    that's what i was thinking... first thing i would check if there doesn't appear to be any leaks.
    Get it on the Vag Com as aragorn said, Ł10 off eBay for a cheap one.
    Oct 2009
    50
    The temp guage doesnt work lol, i was putting it down to a faulty thermostat, will get the lambada and maf checked out, pretty sure there is a garage near me that uses vag com so ill get it booked in.
    Thanks!
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    Can you be a bit more specific about what you mean when you say there's a bit of vapour on the drivers side, eg:exhaust, engine bay, etc.
    Is there a fuel smell inside of the cabin or perhaps any smoke when the car is stationary?
    Sounds like a hell of a lot of fuel to be using if it's just a duff sensor. A dodgy MAF or lambda sensor would affect fuel consumption, but it's unlikely it would increase 250% like you are seeing. I would be looking more along the lines of a leak. Check around the fuel filter for signs of leakage.
    Leaking fuel will evaporate quickly so just because you don't see a puddle like you would with an oil leak doesn't mean that fuel isn't leaking somewhere.
    Mo power, mo problems
    Feb 2007
    Liverpool
    1,693
    Ah, temp gauge doesn't work... could very well be the ECT sensor at fault. A quick, cheap and easy fix.
    "Stick a V8 in it!"
    15,385
    If it doesnt work at all then its prbaby the sensor.
    duff stat would probably allow it to at least move the guage.
    Vagcom will hopefully tell you whats wrong, dont take it to a garage, buy your own lead.
    Oct 2009
    50
    Buy a lead and do what with it? (sorry im a total noob at this stuff)
    Dec 2009
    Cheltenham, UK
    65
    http://www.audi-sport.net/vb/forumdi...VAG-COM)-forum
    have a look there. its basically software + lead which plugs a laptop into your car, then it runs through a list of presets to see if anything is abnormal. so you can see if a sensor is not working, or reset the air bag light etc.
    good bit of kit, and only Ł10 if you get a lead off eBay and use the free version of the software (doesnt give u all the descriptions, but these can be found online)
