AH FabricationsVolks Autos
    imported_druggie
    How to tell if turbos need replacing in as S4?
    Appart from the tell tale noisy turbo bearings , how else can you tell if the turbos are faulty or need replacing?
    What checks can the workshops perform to tell one way or the other?
    imported_ZeroK66
    Re: How to tell if turbos need replacing in as S4?
    if the car is not holding boost... boost gauge best way to tell that... if it holds boost evenly through the revs then should be fine.
    28v6
    Blowing Oily Smoke... Not holding boost, Not boosting at all, noisy.... That's about it really...
