Chris NottEM Tuning
Results 1 to 8 of 8
    Apr 2009
    birmingham
    109
    Airbag lite on!!!
    Coming home last nite, i got to my car started it up and my airbag lite have been stuck on every since,
    is this going to be a quick fix or is it going to hit my wallet hard?
    Cheers peeps for ur help
    Gareth
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,914
    Only vagcom will tell you!
    Its quite likely to be the airbag wires under the seats.
    TD5 Land Rover Defender build
    tazzy baby's Avatar
    Rookie
    Feb 2009
    south wales
    545
    Hey hey another gareth with an audi who would of thought,,,, two gareth's with great taste in cars lol
    Mine done that the other day come from asda got in started it up and the light was on took it to my brother and he reset it and its been off ever since but i dont have any wires going to my seat
    If you give a mouse a cookie......
    He's gonna want a glass of milk....
    vorsprung durch technik
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    yep as aragorn says had the same issue with mine once you have vagcom'd it and if it turns out to be the seat airbag connections either take out the plug and tweak the tiny plug (female) in my case i bent the pin a bit so it made a better connection or change the connection alltogether. Bear in mind while the AIRBAG light is on ALL airbags are disabled, even if you find the fault you will need to reset with airbag light with vagcom.
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    Apr 2009
    birmingham
    109
    thanx for help, who would of thought it 2 gareth with great taste lol, ill got my mates garage and get it reset and go from there,
    "Stick a V8 in it!"
    14,914
    Dont just reset it. The fault code will tell you exactly whats wrong. Read the code, fix the problem!
    Apr 2009
    birmingham
    109
    im not going to just reset it, that just plain silly, as im going to be puttin the car up 4sale soon.
    LPG Abuser & have VAGCOM
    Aug 2005
    Essex
    167
    Sounds like that is a common place for it to go under the seat!
    When my Missus drive the car she moves the seat and up the light pops!! Then its a trip to my friends with vagcom!
    I think I will do the little tweeek now...
    Michael
