Chris NottSky Insurance
Results 1 to 14 of 14
    mugglesquop's Avatar
    Dec 2009
    Cheltenham, UK
    65
    Power Steering Fluid
    Hello.
    does anyone know which oil i need for the power steering? on the tank it says about using Mineral Oil.
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,065
    i used genuine audi stuff about 7 for a litre if i remember correctly
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    Sep 2009
    Essex
    2,366
    what he said. not worth putting the wrong thing in
    Dec 2009
    Cheltenham, UK
    65
    Quote Originally Posted by olds_kool View Post
    Do you know what the spec/type is?
    Sep 2009
    Essex
    2,366
    then ask yourself what happened to all the old stuff cos a leak is going to have to be fixed
    Dec 2009
    Cheltenham, UK
    65
    Quote Originally Posted by Matt82 View Post
    i'll keep and eye on it. its not quite down to the minimum mark. it hasnt lost any since i've had it (2 months)
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,907
    You want "CHF11S"
    TD5 Land Rover Defender build
    Dec 2009
    Cheltenham, UK
    65
    You want "CHF11S"
    that is a synthetic oil though. It says on the tank to use Mineral Oil only... or does it not matter?
    "Stick a V8 in it!"
    14,907
    Its a "synthetic mineral" oil.
    Audi G002000 = Pentosyn CHF11S
    It used to be CHF7.1, which was pure mineral, but audi superceded the same G002000 part number to the newer chf11s type, so if you buy it from audi your getting chf11s anyway.
    http://www.blauparts.com/audi/audi_f...ic_fluid.shtml
    The important bit quoted here:
    Audi tech bulletin 48-89-T07 issued in November 1989. It states "The new [synthetic Pentosin 11S] and old hydraulic fluid [non-synthetic Pentosin 7.1] can be mixed if necessary ... the part number [remains] unchanged." So according to Audi, you can mix the 2 Audi hydraulic fluids. Even though the composition of the fluid changed (CHF 11S synthetic mineral oil vs CHF 7.1 non-synthetic mineral oil), Audi didn't even change the part number. All 1990 - on Audi models have come filled from the factory with the synthetic CHF 11S Audi hydraulic fluid (G002000)
    Dec 2009
    Cheltenham, UK
    65
    ahhh i see.
    brilliant, thanks very much
    jcb
    Sep 2005
    uk
    4,070
    do you have a engine pan fitted (plastic thing under the engine?
    run your finger between it and the lower edge of the bumper on the left hand side of the car.
    bet you it is a bit sticky.
    I have the same leak.
    Lower PS pipe connection where it goes from rubber to solid lines.
    just needs a jubilee clip as it currently has a crappy "use once" clip
    Dec 2009
    Cheltenham, UK
    65
    Quote Originally Posted by jcb View Post
    i will check, but i had the pan off to do a oil change the other day, and it was all clean then (as far as i can remember).
    think its just the fact that its 13 years old. i only checked it as it was due a Inspection II. in the 2 months i've had the car it hasnt gone down any.
    '97 A4 1.8TSport Avant
    jcb
    Sep 2005
    uk
    4,070
    it won't be on the pan it is more likely to be on the bottom curve of the bumper.
    Dec 2009
    Cheltenham, UK
    65
    will have a look this afternoon, cheers
