I'm looking to fit the Waeco MS-50 cruise control kit to a standard audi indicator stalk.
The servo is vacuum operated and requires a vacuum source, presumably there is an existing pump.
Is this easily accessibly on a 1.8 A4 and is it a constant vacuum source or does it vary depending on the load, e.g. brakes?
Also how easily accessibly is the drive shaft as it requires a magnetic speed sensor to be attached to it.
Not too sure so thought I would check first!!
Thanks!
