therealnovaboy
Missed A Gear
I was if anyone new the service interval for changing the rear diff oil ? I cant find this info anywhere.
Should the gearbox oil be changed at the same time or is it a matter of only checking the level and topping up where neccessary?
Also is there a drain plug on the diff to drain the oil or do you just have to pull out the shafts?
