Volks AutosAH Fabrications
Results 1 to 10 of 10
    Aug 2009
    191
    Wanted:Front Drivers side Hub assembly/wheel bearing housing for 2000 1.8tqs
    Has anyone got a spare front hub assembly? basically need the bit that all the ball joints connect to. Someone has put a different one on my car, including a smaller cv joint to fit the hub!! Bloody cowboys what next..
    part number will be something like this 8D0407258AE or 8D0407258AM. The correct one on the passenger side is 8D0407257AE.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,503
    Hi there i have in my possesion a set of uprights with 82mm bearings and matching CVs. Removed i believe from a 2003 Passat Diesel, i bought them in error
    Part numbers are 8D0 407 257 AR and 8D0 407 258 AR. Any use?
    Aug 2009
    191
    not sure if those would fit mate, cheers anyway.
    Apr 2004
    12,503
    Ok no probs.
    Will retain them for use on my TQS
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    ive got one but cant remember which side it is, will check for you tommorow
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,299
    Neil: i suspect Byzan's ones will fit just fine, the passat has B5 running gear, and they're the larger 82mm bearings so should slot streight on.
    TD5 Land Rover Defender build
    Aug 2009
    191
    maybee as a last resort i'll put one with a different part number on, just don't want to fit the wrong one cheers.
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    got drivers side ending in AE, was from my car as i fitted s4 ones and bearing is good, pm if you want it
    kev
    90 eunos roadster
    Aug 2009
    191
    Quote Originally Posted by olds_kool View Post
    you have pm
    Apr 2004
    12,503
    All sorted, so closed. Thanks
