EM TuningVolks Autos
Results 1 to 13 of 13
    gaz71's Avatar
    1.8T Quattro Sport AJL
    Jul 2009
    Torbay
    287
    Damn stuck stereo
    Hello again guys,
    I need to get my concert radio out but the right hand clip just won't give it up
    Any ideas of how get the damn thing free or another way to get the radio out
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    Hi i assume your using one of these? http://shop.ebay.co.uk/?_from=R40&_t...All-Categories
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    26,720
    If its stuck, which is possible & not unheard of, you'll have to get in from behind to wedge say a flat screwdriver in to release the bracket or go from the front but would damage the unit & the trim area, so try from behind which involves removal of trims/glovebox etc, crappy job for sure.
    Jun 2003
    World of my own
    9,813
    You can't get to the clip from behind. Best option is to gently prise off the entire front facia of the HU which will give you access to the clip
    Alex Turner
    26,720
    I would disagree as I've known of someone to do this from the rear somehow, but if your suggestion works easier & quicker then all for it, but isnt the fascia screwed on with torx headed screws?
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    try going in at a strong angle towards the outer side of the unit as if to hook it back to the inner side . If this doesnt work trim the key down a bit more and try again , ive had many a stuck vag stereo and donr this and every one has come out doing this.
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    DO NOT prise the front fasia as there are 2 8m screws holding it to the console mounting hidden under the sides otf the stereo.
    just seen you was refering to headunit fascia yes this is possible but easy to break bits off it too.
    gaz71's Avatar
    Jul 2009
    Torbay
    287
    Just out of interest, is there a nut holding the radio in place?
    There is a bolt on the back of my replacement radio and the one I'm trying to remove is the original.
    I don't think it has ever been removed.
    denzelburner's Avatar
    Sep 2007
    Devon
    166
    The bolt on the back is for the stereo to dissipate heat, and doesn't attach to anything else. Best bet is what rasA4 said, and try with the radio removal keys. I just popped over to my local friendly garage who took it out for me for a couple of quid
    If you can't beat them, arrange to have them beaten
    2000 B5 2.5tdi V6 (if only it were a quattro)
    Jun 2003
    World of my own
    9,813
    Bolt on the back is actually for support, it rests in a rebate behind the dash to relieve the pressure on the HU cage. Chances are the spring clips have been bent out of shape by the failed attempts at removal. If that is the case the removal keys will not budge it.
    Alex Turner
    gaz71's Avatar
    Jul 2009
    Torbay
    287
    Tried with the removal keys and still no joy.
    The radio comes out about 15mm then won't budge.
    Looks like I'm going to be doing some serious dismantling this weekend
    gaz71's Avatar
    Jul 2009
    Torbay
    287
    Got the damn thing out
    Sheer brute force did it in the end, with a bit of help from a small screwdriver.
    Problem was the clip was totally mangled and bent.
    New one from olds_kool fitted, no annoying volume control
    I am one happy man
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    Well Done gaz!
