Sky InsuranceEM Tuning
    May 2004
    9
    Instrument Problems
    Hi
    Could anyone help me with a problem with the dash on my 99 pre facelift S4?.
    The fuel gauge is acting like a rev counter, moving up and down with the revs causing the "miles left per tank" reading on the display panel to do the same. Also the speedo is not working and the milage is not clocking on the display. The same problem occured a few months ago but fixed itself after I switched the ignition off and restarted it, this hasn't worked this time.
    Does anyone know if there is a common sender for both the fuel gauge and speedo which could be faulty, or in the worst case the rough price of a new dash.
    Cheers for any help
    Jim
    Apr 2004
    Sydney, Australia
    262
    Re: Instrument Problems
    do a seacrh on this, theres loads on the forum about this.
    Nov 2003
    Wa, USA
    248
    same thing on my A4, i had a bad fuel sensor.
    May 2004
    9
    Cheers!
    The speedo etc is now working again for now but i'll have to try and sort it out.
    The speedo seems to go off first, like a bad connection then when completaly dead the fuel gauge goes mental.
    Would the fuel sensor affect the speedo aswell as the fuel gauge, the car seems to be running fine otherwise.
    Would this show up on a VAG.COM.
    Thanks again
    Jim
    Nov 2003
    Wa, USA
    248
    so both your speedo and fuel are on the fritz? if so, sounds like something in the cluster
    May 2004
    9
    That was my first thought, hope its a connection and not the cluster, its still working fine for now
    Jim
