EM TuningChris Nott
Page 1 of 2 12 LastLast
Results 1 to 40 of 72
Thread: Cruise control?
    rob v6's Avatar
    Learning the VAG way
    Oct 2009
    Dudley
    161
    Question Cruise control?
    I am looking at getting cruise control fitted to the A4 but does any one know if it is possible to do i drive a 2.4 v6 A4 w reg se avant Automatic.
    If it is possible what would i need and where would the best place be to get the parts ie audi part numbers if you have them
    thanks rob
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    yep mine is the same as yours in the saloon variant
    got mine done about 7 years ago from an audi specialist for 200, before i knew anything about vag.com before hand its pretty simple as its a DBW (drive by wire) just need to take the old stalk off and replace with cruise and tell the ECU via vag.com that cruise is required, thinks its pretty much much it. havent done this myself but should be along those lines.
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    tazzy baby's Avatar
    Rookie
    Feb 2009
    south wales
    545
    Hey guys do you know if that can that be done to a 1.8t 1997 fwd a4 avant AEB
    If you give a mouse a cookie......
    He's gonna want a glass of milk....
    vorsprung durch technik
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,324
    You need to add the loom from the stalk to the ECU, kufatek does it for about 14quid though.
    TD5 Land Rover Defender build
    "Stick a V8 in it!"
    15,324
    tazzy: AEB needs quite a bit more work, as its a cable throttle car, You need the vacuum pump, actuator, brake and clutch switches, and the control unit, and you need to make your own wiring harness for it.
    rob v6's Avatar
    Oct 2009
    Dudley
    161
    so basically i need to buy the stalk and get a wiring loom to make it work and thats it oh and tell the ecu i have cruise control via vag com.
    what does the wiring loom do and where does it go?
    rob v6's Avatar
    Oct 2009
    Dudley
    161
    Quote Originally Posted by rob v6 View Post
    i take that as a yes then
    rob v6's Avatar
    Oct 2009
    Dudley
    161
    who is kufatek
    rob v6's Avatar
    Oct 2009
    Dudley
    161
    found them so which is the best one to buy
    either this
    http://www.kufatec.de/shop/product_i...-A4-8D-B5.html
    or this
    http://www.kufatec.de/shop/product_i...B5-8D-TDI.html
    than get a stalk from either a delaer or a scrap yard ie a a4 or a6 or a8
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    i bought the kufatec stalk and harness for my tdi, stalk only comes in german but once you know how to use it you dont read it anyway
    its a pain to fit harness, i found this helped
    http://www.vwaudiforum.co.uk/forum/s...ad.php?t=36573
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    LPG Abuser & have VAGCOM
    Aug 2005
    Essex
    171
    If you need any pictures of the OE system I can provide some..... Mine ad it fitted as standard! Its vacuum on a AJL QTS cable throttle.
    rob v6's Avatar
    Oct 2009
    Dudley
    161
    Quote Originally Posted by Rallyman View Post
    if you could mate that would be grate will be trying to get the parts ant the weekend so i can get it fited before i go on holiday
    Aug 2005
    Essex
    171
    Tom Cruise control
    Vacuum dissapears underneath the ABS block, Hope these are some use?!
    Michael
    By null at 2010-02-02
    Whooops pics are a bit big..... LOL full of detail!
    Michael
    "Stick a V8 in it!"
    15,324
    They wont be any help to him, as his car is drive-by-wire
    Just buy the "TDi" harness and get a stalk from ebay.
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Besides an A4 cruise stalk, what other vehicle can I source one from?
    I'm assuming as mine is a facelift 1.8T, it'll be drive-by-wire, so a little easier to install?
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
    "Stick a V8 in it!"
    15,324
    Not all facelift 1.8t's are DBW, but if it IS DBW, then you just need the stalk and the loom to the ECU.
    The stalk in ours is from an A8, same part number etc.
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    How can I check if it is actually DBW then?
    PM me for more info
    "Stick a V8 in it!"
    15,324
    Does it have a throttle cable?
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Never noticed one... so I guess not! Doh!
    But... saying that, the last pic shows a cable underneath the TB - is that not a throttle cable?
    PM me for more info
    "Stick a V8 in it!"
    15,324
    If you look at rallymans last pic, you can see the throttle cable attach to the black plastic cam on the front of the TB then go off under the inlet. It goes thru a little bracket then along beside the fuel rail.
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Nope... mine's not got one of those! lol
    PM me for more info
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    epc light on dash ? (electronic pedal control)
    kev
    90 eunos roadster
    rob v6's Avatar
    Oct 2009
    Dudley
    161
    how much are the stalks from a main dealer?
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Dunno... but there's one on eBay for 60.
    I've just managed to find one from a breakers yard for 30... result!
    Just the harness to get now... and someone to 'vagcom' it for me.
    PM me for more info
    rob v6's Avatar
    Oct 2009
    Dudley
    161
    I will have to go down the scrappy and see if they have any in
    can not see the one on ebay for 60
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    PM me for more info
  28. #27
    rob v6's Avatar
    Oct 2009
    Dudley
    161
    Thanks for that mate i will see what i can get at the weekend first.
  29. #28
    Izzy1's Avatar
    Vorsprung Durch Technik
    Sep 2008
    Birmingham, UK
    348
    I've fitted one in the Bora and it's not that difficult. mind you that isn't DBW.
    fit stalk, connect harness to ECU and vagcom it!
    works a treat. brought from the main dealers for 65 and it came with full instructions.
    don't see how the A4 will be much different. thinking to get mine done sometime in the summer.
    will have to see if it's DBW or EPC. think the EPC ones are much easier to fit.
    Izzy
    Bora TDI sport
    Audi A4 TDI
  30. #29
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    if its a tdi its dbw (drive by wire) think you mean dbc
    kev
    90 eunos roadster
  31. #30
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Ordered my stalk... off to order harness now.
    Stalk is about 85 + VAT from dealer (according to VAG CAT)
    PM me for more info
  32. #31
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    So, stalk and harness ordered.
    How long will it take me to fit the harness...?
    I'm assuming that I'll still be able to use the car safely, even if I've not VAGCOM'd the cruise in...? Need to find somewhere/someone that will do it for me...
    PM me for more info
  33. #32
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    allow a couple of hours, fair bit of dismantling and getting to connector for pins is very fiddly
    if you read the guide i posted earlier (its for a passat but wiring is the same) it will give you a good idea
    kev
    90 eunos roadster
  34. #33
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Yeah... just reading that now.
    I thought the harness would be plug&play... not a lot of fiddling with splicing wires into different connecotr blocks!
    I'll bet you a tenner, when I'm done, the car won't even start! lol
    PM me for more info
  35. #34
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    the kufatec harness isnt even colour coded so you have to take extra care
    kev
    90 eunos roadster
  36. #35
    "Stick a V8 in it!"
    15,324
    Presumably the kufatac harness is built using genuine wires/connectors? If so it will all be yellow. VAG policy is that all modifications to the wiring harness are done in yellow cable for ease of identification.
    Still its only 4 or 5 wires your connecting up, and i'd imagine all you'd have to remove is the drivers knee bolster and the plenum cover.
  37. #36
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    What's the plenum cover...? Is that the ECU cover, but in posh-speak?
    PM me for more info
  38. #37
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Slightly off topic... but what's that large connector circled in red, and all the cabling marked red and green in this pic...? I've got none of that in my engine bay...!
    PM me for more info
  39. #38
    "Stick a V8 in it!"
    15,324
    Its his LPG kit
    And ye "plenum" is audis posh-speak name for the box that contains the ECU etc.
  40. #39
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Aaaaah, that's okay then. I've had the 'plenum' cover off once already to get power down into the foot-well for my amp...
    And the knee bolster has been off more times than I care to remember to fit stereo/hands-free/iPod stuff anyway! lol
    PM me for more info
  41. #40
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Okay chaps... I need some advice.
    My local scrappy has a couple of pre-facelift A4's in... one of which happens to have Cruise Control!
    So what I need to know is, will this pre-facelift CC stalk plug into the harness I've ordered and work with my facelift DBW set-up?
    If not, does anyone want it...? I should be able to get it out without a problem. I went there today, but didn't take any sockets with me so couldn't get steering wheel off to get to the stalk... Fail! (I went there for something else, then saw the CC stalk!)
    PM me for more info
