Monster MotorsportEM Tuning
Results 1 to 11 of 11
    Dec 2009
    7
    Rear speakers blown
    Hi, Not long after I bought my B5 recently the rear speakers blew. I wasn't hammering the tunes out or aynthing like that, they just blew. They look lke the original speakers.
    I hope to buy some new ones this week, but can anyone tell me what size I need to get?
    Also, is it common for speakers to just blow, or could it be incorrect wiring by the previous owner? This has never happened on any of my other cars and some have been older.
    Any help would be great!
    S4twiggy's Avatar
    Fully Certified Detailer!!
    Feb 2009
    South Wales
    1,811
    i think the B5 are ****e when it comes to spoeakers. my old A4 had buggered rear speakers and now my S4 which has bose system also has the rears blown out, i jus unplugged them and will fit a little sub to give that little extra base i lost from the rears. measure the onesyou have and then that will tell you wot size you need, you need to take them anyway so measure when out.
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    the rear shelf speakers have a square fitting at the base you can get adaptors however i dont recommend them.
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    Aug 2009
    Dorset, UK
    171
    If your car has a Bose system it is 2ohm which dose not leave you with a lot of choice for replacements. My rear shelf, subs had gone too so I replaced mine with Kicker CVT 65 they are available in both 2 & 4 ohm. You can get them to fit by using the cone/adapter when you remove the old speakers. It takes a bit of work but its will fit like OE units & the Kickers sound great.
    Jun 2003
    World of my own
    9,813
    If it's the non Bose system and you are running the stock HU then you can't just replace the speakers as the left one has the rear amp built into it. If you have an aftermarket HU then there's no problem as you can simply rewire them back to the HU. They are 6.5" coxials BTW and as said you will need adapters.
    Alex Turner
    Dec 2009
    7
    Thanks for the replies.
    The head unit is sony, so does that mean I can just buy new rear speakers and not have to worry about he amp? I'm not sure why I need the adapter, it looks like they would just slot in? If I do need it where do I get it from?
    I really appreciate the help guys. I used to have an old mercedes 190 and there was a forum just like this for extra info and stuff.
    Thnx, andy
    Dec 2009
    7
    Quote Originally Posted by rasA4 View Post
    Why don't you recommend them? Can I install them without these?
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    if they are anything like the front adapters poor fitting basically, when i changed the stock fronts they sounded worse!
    with regard to your rears if they are standard stock speakers you will need to remove the whole rear shelf and watch for the high level brake light plug you will have to unplug it from the boot. you may be able to see from the boot that they have a square hole
    http://caraudiosecurity.com/shop/pro...s_id/1884.html
    Jun 2003
    World of my own
    9,813
    It's just the rear shelf cover, it simply pops up and slides out, but is only easy if you have folding rear seat backs.
    The adapters are OK for the rear, and at least they are installed onto a metal rear deck as opposed to the flimsy doorcards the front ones use. Also check the wiring, as the previous owner may have already rewired them to the Sony and that would explain why they blew so easily as they would have over twice their rated power going to them (the stock rear amp is a puny 2 x 20w).
    With the adapters you can install pretty much any 6.5" coxial speaker.
    Alex Turner
    Dec 2009
    7
    Appreciate the help guys!
    Izzy1's Avatar
    Vorsprung Durch Technik
    Sep 2008
    Birmingham, UK
    348
    Quote Originally Posted by AndyMac View Post
    does anyone know how to get the shelf out as my rear seats don't fold.
    Izzy
    Bora TDI sport
    Audi A4 TDI
