Monster MotorsportChris Nott
Results 1 to 8 of 8
    gaz71's Avatar
    1.8T Quattro Sport AJL
    Jul 2009
    Torbay
    287
    Cd player security code
    Hi all,
    I want to get a replacement radio for my Concert Radio as the old one has the usual volume control problem, two settings - quiet or LOUD.
    I've seen some Concert CD players on ebay going fairly cheap without security codes. Can these be recoded using VAGCOM?
    If not does anyone know what sort of price I'll be looking at to get one recoded.
    Thanks in advance,
    Gareth
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    Hi Gareth, you could try this company http://www.radio-code.co.uk/audi-radio-codes.html i havent used them so cannot comment if there any good
    also why would you need the code? tbh dont think ppl would steal the radio? from our age of cars?
    i dont think you can enable the radio code via vagcom
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    gaz71's Avatar
    Jul 2009
    Torbay
    287
    Thanks for that, I'll give them a try.
    Been looking at some on Ebay and not all of them have the codes for some reason or another
    Want to replace the tape Concert I've got at the mo with something nicer (and without the annoying volume control issue!!)
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    the code wouldnt bother me personally
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    main problem is they will only supply the factory code for the unit , you can actually find a program to generate vag radio codes from serial number , i had one but cant remember where it came from now but im sure if you google it you will find it . Usually came up with 2 different codes but one will work unless it has been recoded.
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    gaz71's Avatar
    Jul 2009
    Torbay
    287
    Thanks for all the input. But just to clarify,
    wouldn't the unit ask for a code once fitted to the car as the power would have been disconnected?
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    IIRC i dont think so, as its an option to disable the code the previous owner would have needed the code to disable it.
    also if your buying from eBay ask the seller if when fitted to your car will it ask for the code? if he/she says its ok at least your covered
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    yes it would but the original codes are found through the serial number and do not change from factory unless someone has re coded .
