JMB RetrofitsChris Nott
Results 1 to 12 of 12
    rob v6's Avatar
    Learning the VAG way
    Oct 2009
    Dudley
    161
    Exterior door trim
    evening how is everyone?
    does any one know if it possible to replace the trim at the bottom of the door (exterior) and how much it is either main dealer or else where or if something else can be fitted ie from a newer sline.
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    Think front door is about 20 and rear about 15 from audi. you can get s4 ones but very expensive and wouldnt work right without the skirts etc. What doors do you need the trims for? Ijust took all mine off and they are ok,2 are about a year old.
    rob v6's Avatar
    Oct 2009
    Dudley
    161
    all of them need replacing as the metal runner that is inside the strip has gone rotten and does not clip onto the door properley
    May 2008
    perth
    1,197
    I'll check all mine later and see what the back of them are like. 2 I know are like new anyway.
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,088
    Euro Car Parts do these and they are a bit cheaper than teh dealer and are a dealer part.
    Life begins at 140mph
    www.passionford.com
    tazzy baby's Avatar
    Rookie
    Feb 2009
    south wales
    545
    Funny you should say that mine are gone aswell on all doors and also the rear drivers door trim has gone to the one thats half way up the door any one know how much they are thanks
    If you give a mouse a cookie......
    He's gonna want a glass of milk....
    vorsprung durch technik
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,088
    iirc they were about 18 each
    www.passionford.com
    Road Razor's Avatar
    Tyne & Wear
    390
    They're prone to rust and rot from the inside. The replacement trims are a newer design made of hard plastic inside. There's quite a fair number of b5s I've seen with at least one of the trims removed, leaving behind a row of white clips.
    I've had all my door trims and clips removed, dremelled the studs, patched up the holes. All my trims were colour keyed, therefore it wasn't worth replacing a single trim and respraying it. It even looks better than before.
    A4 2.4 V6 2000.
    tazzy baby's Avatar
    Rookie
    Feb 2009
    south wales
    545
    Quote Originally Posted by Road Razor View Post
    have you got any pics butty
    Road Razor's Avatar
    Tyne & Wear
    390
    Quote Originally Posted by tazzy baby View Post
    The sills and door trims had already been painted. This is how it looks without the door trims & corner trims.
    Those holes in the corner will be patched up as of next week.
    This is how it looked before with the trims on:
    A4 2.4 V6 2000.
    Jun 2004
    Northants
    126
    I've replaced some of my door trims from Audi direct, they're about 18 each.
    BigJimKnickers's Avatar
    Mar 2010
    Guildford
    17
    I need to replace mine too, is the 18 from euro car parts just for the outer trim? Or all the necisary parts to replace? Some donkey cock who owned my A4 has screwed the driver door one on with a self tapping screw!! Looks bloody awful.
    BigJimKickers - PSN
    2000 2.5 TDI V6 Saloon
