    gaz71's Avatar
    1.8T Quattro Sport AJL
    Jul 2009
    Torbay
    287
    Climate Control Codes
    When I changed my stat recently I used to climate control to see what temp the ecu was reading (code 49).
    Does anyone have a list of what the other codes read, if anything?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    http://www.audiforums.com/forum/arch...p/t-21703.html
    According to that, 49 is a manfunction indicator of some form, and 51 is the coolant temperature....
    TD5 Land Rover Defender build
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    It's not 100% that list. I'm guessing the US spec cars were coded slightly differently.
    49 and 51 both seem to be Coolant Temperature, although they are usually a few degrees out until they hit 90. Guess one is the value sent to the cluster and the other to the ECU.
    Mo power, mo problems
    gaz71's Avatar
    Jul 2009
    Torbay
    287
    Thanks for the info chaps. Much appreciated
