Volks AutosAH Fabrications
Results 1 to 14 of 14
    Jun 2008
    29
    Help, I've killed my car!
    hi,
    I fiited a new stereo to my car on sunday (didnt drive it afterwards) and on monday morning it started up but the EPC light and an engine warning sign came up. It wont rev or tick over. I have taken the stereo back out but its still the same. It may not even be the stereo and maybe just failed at the same time. These are the faults codes- it does kind of look electrical, any help would be great- i am having to cycle to work!
    9 Faults Found:
    16621 - Manifold Pressure / Boost Sensor (G31): Signal too Low
    P0237 - 35-00 - -
    16725 - Camshaft Position Sensor (G40): Implausible Signal
    P0341 - 35-00 - -
    16490 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
    P0106 - 35-00 - -
    18047 - Accelerator Position Sensor 1/2 (G79/G185): Implausible Signal
    P1639 - 35-10 - - - Intermittent
    16486 - Mass Air Flow Sensor (G70): Signal too Low
    P0102 - 35-00 - -
    16706 - Engine Speed Sensor (G28): No Signal
    P0322 - 35-10 - - - Intermittent
    17952 - Angle Sensor 1 for Throttle Actuator (G187): Signal too Large
    P1544 - 35-10 - - - Intermittent
    17580 - Angle Sensor 2 for Throttle Actuator (G188) Signal too Low
    P1172 - 35-10 - - - Intermittent
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    Apr 2009
    Coventry
    2,219
    Id check all the fuses and relays first
    Pass me my sock
    Want to help cure cancer? http://folding.stanford.edu/English/HomePage
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    Possibly a daft question, but have you cleared the codes to see if they all reappear?
    Mo power, mo problems
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    it looks like a major earth or power feed is missing...
    As blue says, clear them and see what comes back.
    TD5 Land Rover Defender build
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    I am with him. Thats a major failiure of componenets just to "happen" overnight. You have more likely pinched a wire or accidently cut one somewhere
    Jun 2008
    29
    yeh, the faults were cleared and came back exactly the same.
    Jun 2008
    29
    just cant work out what i have done. all i did was remove the old stereo,plug the the new lead in and fitted new stereo.i checked for damaged wires and cant see anything.
    "Stick a V8 in it!"
    15,370
    Cant really see why any major engine signal cables would be in/around the stereo either...
    What year is your car? perhaps you could check over all the earths in/around the engine bay and around central electrics?
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    what stereo was it?
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    Jun 2008
    29
    its a 2000 1.8T.
    The stereo is a Sony. That works fine, i can sit in the car and listen to the stereo, i just have to stay on my driveway to do it!
    The wiring was really short to the stereo and i probably did pull on it a bit to reach it, i wonder if another wire pulled out somewhere in the process.
    i've been googleing the fault codes and the accelerator sensor seems to cause people all sorts of trouble so i will have a look at that but it seems a coincidence that it all happened after the stereo fitment.
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Mine had similar problems at one point. Turned out to be a faulty MAF.
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
    Jun 2008
    29
    ok, now fixed. It turned out to be the MAP sensor. I bodged it a bit when i fitted the intercooler last year and i mounted the MAP too close to the chassis leg. The wires had worn through and were either shorting to each other or to the leg. This must have upset the values for the other sensors that came up. With the lap top connected and continually being cleared we could see that sometimes it was only the MAP that came up so that pointed us in the right direction. I cant beleive it failed the day after the stereo was fitted and this sent me completely down the wrong path. Unfortunately i had half the inside of the car stripped looking for the fault before my mate turned up with his laptop. Thanks for the replies, no more cycling , my butt was killing me!
    "Stick a V8 in it!"
    15,370
    That explains it, presumably the 5v feed to the sensor was getting grounded, and it was shared amongst those other sensors, so they were all dropping out.
    Do you mean the air flow meter (MAF)?
    Sep 2009
    Essex
    2,366
    fantastic. a had an issue a tiny bit like that once where a load of sensors dropped out. i scratched my head a bit and realised they were all on the same spur of the loom. one patch up later and all was done
    obviously i dont know the audi lay out that well yet but full credit to you for sorting that one out. shows you how much trouble the little "bodges" we sometimes do can get us into
