Results 1 to 14 of 14
    floyd 1.8 turbo's Avatar
    Mirror, Signal, Outmanoeuvre
    Apr 2008
    Bracknell, Berks
    630
    Question Pre to face boot lid swap
    Will a facelift bootlid directly fit onto my pre? I know it will fit but are bolt holes in correct place and are wiring plugs the same?
    Can this be a straight swap??
    TA!
    White B5 1.8 turbo sport
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    The one you're after (mine) doesn't have the in-boot wiring loom with it - you'd need to use your existing loom... as it attaches to the main car loom. Not sure how the pre-facelift wiring works, but I'd guess that it's not a completely straight forward job.
    All the connectors are there and working... just need to see if anyone here knows what's involved with the swap-over.
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    pre facelift uses air line for locking system facelift is electric so its not a straight swap
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,299
    The pre-facelift cars have a mechanical pop, with a normal locking mechanism on it, run from the CL pump, like the door locks.
    Facelift cars dont "lock" they just have an electronic solenoid that opens the bootlid, and a pair of microswitches on the lid to activate the solenoid when the car is unlocked.
    You'd need a facelift central locking pump and associated loom, if you wanted to fit a facelift tailgate.
    TD5 Land Rover Defender build
    Oct 2009
    50
    Sorry to butt in here but will the facelift tails fit pre-face cars without modification?
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    The units will swap over mate, but there is a pin swap on the plugs thats needed as the reverse light has changed position. Simple procedure, just fiddly!!!
    Project RS28 build
    Oct 2009
    50
    Quote Originally Posted by Foxmeister View Post
    Thanks Foxmeister - you saved the day again!! I think my mechanic will be up to that. Cheers again pal
    Apr 2008
    Bracknell, Berks
    630
    Ok thanks all, sounds like it may be quite a mission so as i dont really have the time i think i'll pass, already got enough to do so shouldn't really get involved!! Thanks for the help though chaps
    May 2010
    Val d'Isere
    85
    Sorry to reopen this thread but I just wondered if anyone had any more luck or information on swapping a Facelift tailgate onto a Pre Facelift A4 B5.
    I have a '98 Avant.
    Thanks in advance.
    "Stick a V8 in it!"
    15,299
    Read my post above.
    May 2010
    Val d'Isere
    85
    Thanks aragorn.
    So it's as easy as a facelift pump and rear loom? Would you know if the boot release is controlled by the pump?
    I guess I will need a 3 button key reprogrammed with a boot release?
    "Stick a V8 in it!"
    15,299
    You'd need to find the wiring diagram (look on ebay for elsawin) for PFL and FL pumps and see whats involved. If theres enough similarity you might get away with simply adding pins to your existing harness, but if the harness is majorly different you'll be having a big headache unless your good with wiring.
    The boot release is controlled by the pump. The "open" buttons goto the pump, and if the pump is happy that the boot should be opened (ie the car is unlocked) the pump fires the solenoid.
    You'll need a 3 button fob most likely yes, but you may find your existing two button fob will work ok.
    May 2010
    Val d'Isere
    85
    The pump I have is 8L0 862 257 H.
    RCL is not a factory fitted one.
    I guess this isn't as straightforward as it seems due to the lack of information so thanks for any pointers in the right direction.
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    Ive decided to go ahead and try and fit the facelift tailgate whilst im doing the rs4 widebody. Are all these posts related to getting the tailgate to open on the central locking? ie, if i fitted it as is would the tailgate unlock just by using the key? I might look into possibly making the pfl locking system fit the facelift but ill have to take a closer look. Ive got the internal wiring for the facelift tailgate.
