I
imported_Yaseen
Just got a call from the garage as they are working on the car at the moment.- apparently as i have early A4, i only need the timing belt and tensioners doing as my water pump is on a seperate side and not linked in any way- apparently this changed on later A4`s and my water pump doesnt need changing unless it leaks- if it did leak or break wouldnt affect the timing belt etc
is this correct?
is this correct?
