JMB RetrofitsEM Tuning
Results 1 to 8 of 8
    Sep 2009
    76
    My suspension sits lower in the back than the front
    Why?
    I've just had it lowered 40mm all around and i can just about get my finger inbetween the arch and rear wheel but on the front i can fit my whole fist in. (oooh, sailor)
    Now the garage told me it will settle but these have been fitted to a car for 100 miles before mine so i dont think they will.
    On the front suspension he put the spring with the touching coils at the top, is this correct?
    I've just taken a pic of it now but it's snowing and dark so it's not so clear, but i'll try uploading it...
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,390
    Sounds like they're off the wrong car?
    IE V6 springs on a 4cyl or something?
    TD5 Land Rover Defender build
    Sep 2009
    76
    it's a standard 1.8 petrol 5v
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Are they supersport springs by any chance?
    "Stick a V8 in it!"
    15,390
    Springs are probably for a different model, either incorrectly packaged or badly made.
    Mar 2009
    Bethesda, North Wales
    40
    same here
    i have also got this 'problem' and trust me it doesnt settle. the spring i have are apexi, good set massive difference, would 'sport' top mounts solve the issue or are they the same size as oem??
    another words i should have spent on full adjustables i know
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    Not sure why this happens but it seems common on SE cars.
    When i lowered my SE on Eibach springs it was the same, i ended up removing the rubber/alloy insulator from the bottom.It sits between the spring and the shock sring cup. That made a huge difference, but it was still too high for me so i pikey'd it and removed the end off the spring with a grinder. She was a nice stance then.
    I did however migrate to coolies afterwards for adjustability sakes.
    "Stick a V8 in it!"
    15,390
    If its a progressive spring, cut the top coil off and see how that goes.
