Chris NottMonster Motorsport
Results 1 to 8 of 8
    132
    Suspension / Geometry Question
    I will be replacing one or both of the front track rod ends soon on my 1.8 TQS saloon. As I was looking through the audi self-study manuals to find out the settings so I can get all the geometry checked and set up. I came across the various suspension types (and codes) and I can't find the code on my white sticker. The codes it lists are not on my white sticker or anything similar where the arrow points to.
    Can anyone tell me what suspension type I have ?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,384
    Autodata only lists two options iirc. "models with aluminium top mount" and "models without aluminium top mount" or something along those lines.
    TD5 Land Rover Defender build
    132
    Do you have an Autodata Book ? What are the settings for both ?
    thanks
    "Stick a V8 in it!"
    15,384
    Its on the PC at home, i'm not back there until friday though.
    jcb
    Sep 2005
    uk
    4,077
    what settings?
    stock front geometry settings?
    Surely you won't be able to adjust them until it is on the 4 wheel alignment machine. there is very little adjustment in them anyway, short of the subfrmae left right shuffle to match camber and track rod end adjustment to set toe in/out
    "Stick a V8 in it!"
    15,384
    ye, but autodata lists the valid range for the camber and castor, so you can tell if anything is out.
    132
    Thats my thinking. Get the toe set and check the rest, especially before new tyres go on.
    I assume mine has 'sport' suspension, but i can't be cure as I can't find the code on the white sticker.
    jcb
    Sep 2005
    uk
    4,077
    how are you going to measure whether or not it is valid without fitting the arms and getting it on the 4 wheel system?
    But for your info:
    (all Left habnd side data reverse for right hand side)
    Front Castor: -0deg10min to -1deg0min
    Front Camber 0deg10min to -1deg0min
    Front Toe: 0deg05min to 0deg15min
    Rear Camber: -0deg10min to -1deg10min
    Rear Toe: 0deg03min to 0deg13min
    Personally I like my front toe set slightly lower at zero or even slightly toed out, it counters the understeer and makes for a more pointy car.
    likewise I have my rear camber on full negative at just over a degree.
