Chris NottBadger5
Results 1 to 9 of 9
    Aug 2007
    87
    Drivers door not opening from outside.
    Went out to my car at about 11 last night and the door wouldn't open, the handle feels normal but door felt stuck. I figured it was iced closed so tried the pasenger door, which opened normally. Thought it would need a push from inside, but it opened fine.
    Any ideas? I am thinking the lock maybe froze up, but the pin on door was up. Anything I can do to free it off? Its the same this morning.
    jcb
    Sep 2005
    uk
    4,077
    hot water? just stay away from the window glass
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,426
    Add Jimmeh on Facebook
    All four of my doors froze solid yesterday. The boot was free however, so, I clambered through onto rear seats, tugged the handle and gave each door a kick et voila. Same again for the fronts..
    Not sure if the water trick is a good idea at this time? I've read too many posts RE window seals etc splitting from the water re-freezing. (will watch this convo as Im interested in learning more)
    Audi A4 Avant 1.9TDi 130 Quattro Sport.
    WhiteDetails.co.uk - Facebook? Follow me!
    Turbo Lag FTW's Avatar
    Hate those none insured you know who types
    Feb 2007
    Carlisle, Cumbria. Not Geordie nor Scotch!
    233
    Had exact same fault a week ago, had to climb through passenger side and open the door from inside like you, I thought maybe it was the lock barrel and it didnt engage the door handle so I`ll be monitoring this one closely
    Audi A4 1.8T Sport
    jcb
    Sep 2005
    uk
    4,077
    I just tried the key in the lock (to lock while it was warming up!) and it was frozen.
    Poured some neat screenwash over the key as it was going in and it freed immediately.
    could always use a haridryer or heat gun (carefully) to warm it up!
    Water should be OK as it is not going into the seal/door juast warming it enough to free the ice.
    Pulled the entire seal off a rental car in Canada one winter. very funny, but only as it was not my car and I hated it anyway!
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    just get some silicone lube and wipe it round the seals so it wont do it again just be carefull not to get it on paintwork .
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    Aug 2007
    87
    I think its the lock mech thats frozen rather than the seal, as it opened fine from inside, no force needed really.
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    Hmm yeh could be actually , get that lubed up aswell . Might be the rod frozen
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,074
    My drivers door was exactly the same the other morning. I took it for a very short drive and then locked it up again so I don't think anything dried out. Ended up climbing over from the passenger side. By time I was at work everything was normal again.
    I think it's just one of those problematic issues of winter.
    Life begins at 140mph
    www.passionford.com
