Volks AutosChris Nott
    Dec 2009
    Starting when Cold
    I have an a4 Quattro 2.8L that when it is cold and I try to start it, it will crank for a while but not turn over. I then turn the key to the off position and try to start it again and it turns right over no problem. Any Ideas?
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    sticking solenoid?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    You say it will "crank" but not "turn over"?
    Those mean the same thing to me?
    TD5 Land Rover Defender build
    orb
    Carlisle
    57
    I read it the same way aragorn did.
    To crank an engine is to turn it over in my little world.
    I guess you mean that you hear the starter going but it is not engaging with the flywheel thus not turning over the motor?
    If I am correct with the above, then Ian52 is correct, solenoid is fooked.
    V/1999 B5 facelift A4 Avant 2.4 Tip - Black - Full Cream Leather - Needs some better wheels
