Sky InsuranceJMB Retrofits
Results 1 to 17 of 17
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Indicators gone...!
    All of a sudden, my indicators don't work.
    They flash just the once, then stop completely... nothing.
    My hazards work fine though.
    Any thoughts...?
    Giles
    Sep 2009
    Essex
    2,366
    hazard relay switch.
    ive seen a3s do exactly the same
    youll prolly have to pull the dash apart, a bit to get to the hzard switch. inside there there are two relays (hazard and indicator)
    you can swap them over and i bet the indicators work and hazards dont
    if so, you want a new relay. ECP sell the OEM item but far cheaper.
    bring the old one in though as the pin pattern can vary IME
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,505
    30 Hazard switch. Inside it are 2 relays if you fancy soldering/de soldering. For the sake of 30 i wouldnt bother. Facelift ones will pop out of the dash without too much trouble. IIRC the latest revision is a letter above what you have
    Sep 2009
    Essex
    2,366
    nah, ive pulled a couple apart and reassembled, the other one i just jumpered to test which relay was dead.
    there are loads of lettered versions, it definately wasnt as simple as one letter above etc for the revisions. we had issues with there being different numbers of pins with they just gave us the next letter up
    Apr 2004
    12,505
    New relay, which will possibly be the same part number and apparently might be completely different despite only the revision number being diferent, or not. Phew covered all bases i think.
    Jul 2007
    London
    3,211
    Quote Originally Posted by Geeman View Post
    Any thoughts...?
    Giles
    Is your facelift or pre-facelift ? On pre-facelift, the hazard switch is quite easy to pull out of the dash, dont know how to pull the facelifted one as i never done one ! If someone knows how to pull the facelift hazard switch, please let me know too...
    FOR SALE:
    Apr 2004
    12,505
    G has a facelift, its a case of removing the trim at the top of the console( clipped on) and popping the switch out, it is well sprung. It will come out just far enough to release the wiring plug and to allow re fitting.
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Hmmm... will go and have a fiddle now.
    Thanks guys.
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Can't figure out how to get the switch out... Grrrrr!
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Is this the right part no. 8D0941509H 01C...?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,317
    Looks like it to me!
    TD5 Land Rover Defender build
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Still can't figure out how to get the damned thing out... double-Grrrrr!
    Apr 2004
    12,505
    Its only held in by spring clips on the side G.
    Once the top section off the console the whole thing is visable,can you not use a small screwdriver to pry it a bit?
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Got the console cover off... but it's proving to be a bit of a *****. Tried prying it off and damaged something else.
    Will wait till the new part arrives, then I can see how it fits...
    Apr 2004
    12,505
    ok mate, it is a push fit, honest, just tight. !!
    Ooo err mrs.
    Stick some BMW badges on and no one would expect to see indicators anyway!
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    Quote Originally Posted by Byzan A4 View Post
    LMFAO
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Got to wait till tomorrow for the part to arrive.
    Will be using my hands for the time being!
