Badger5Sky Insurance
Results 1 to 9 of 9
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Homemade carbon fibre trims...Yummy!!!!
    Well ive finally managed to start work on the car again and got on with making some carbon fibre parts. Found this site when searching a few months back http://www.carbonmods.co.uk/
    So ordered the skinning kit to do my door and dash trims. After buying a set of poverty spec trims to carry out task on, i started by removing the metal front casings
    Simple enough using a pair of pliers and bending the tabs on the rear back to remove the metal, which exposes a relatively, flat, smooth plastic trim ready for paint etc as i was originally considering.
    Next, i sanded all parts with 120 grit paper to key the base area for a good contact to apply base coat onto.
    Once every area where the carbon fibre would be applied was keyed, i then mixed up the base coat with hardner and slowly applied a smooth, even coat to all parts
    At this stage, the base coat should be left around 3hrs to dry to a tacky finish ready for next stage....cue the Indian menu selection, and a bit of Harry Hills TV Burb!
    Okay, now well fed and watered, this was the tricky bit. Best idea is to pre cut all pieces of carbon fibre, oversized to each part, before you start. Then, probably needing a 2nd person, you need to lay the carbon fibre slowly, and softly so as not to disturb the weave or open any gaps, then work from the middle out and run your hand gently over all areas to get it to bond. You can then trim the excess at the rear leaving about an inch to fold back and tape onto rear of parts.
    The most tricky part was the large dash piece due to shape where the cut out is.
    ^^^You can just see the two cuts that i had to make where the trim has the cut out section, this was vital so that the weave would not pull and distort when wrapping this section around the back of the trim.
    So now i have all the door and dash trims covered, but one or two had some base coat come through slightly on top of the carbon, so i left these overnight to dry properly and also it was after midnight and the mrs was giving me evils so decided to leave it there for the night
    Will continue today with applying the next few layers of top coat before lacquering and polishing to a nice shiny finish, update later on tonight!
    Project RS28 build
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    lookin good so far
    what sort of cost, what have you used and where from, quite fancy havin a go
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    27,121
    Spot on fella, love it, good job.
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    Looking good so far,
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Thanks guys
    Cost so far is the kit from the above mentioned site, all in around 50 delivered, but only comes with around 1metre by 300mm carbon which isnt enuff for this. I already had a larger sheet which i had used on other stuff before and think that only cost 20-30 for much larger roll.
    Its a very time consuming job if you want it perfect like me, but i reckon most people who are good with their hands can do it, just take time and care.
    Havent made any progress since due to my wee girl no being very well so looking after her at the minute, but will likely get the next 2 top coats on and ready to polish up by tonight or tomorrow when i fit it in. Cheers.
    Project RS28 build
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Great write up. Looks like it'll be a top finish too. Excellent!
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Progress of this is in the thread in the project room.
    Project RS28 build
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    cheers, thread here
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Cheers for that Ras, final polish and finish later so will get the pics up later on tonight!
    Project RS28 build
