bmarshall
Hey all does anybody run low com pistons in there 1.8T or 2.7TT for that matter?
If so what boost are you running and how is the low engine speed performance?
Im getting 8.5:1 JE pistons for my rebuild with SCAT rods from 034.
Im doing so for a future BT high boost setup later down the track but going to use a K04 or SP51R-029 setup at the moment.
I might play around with pressures using an eboost2 to see how that goes with pinging etc.
Does anybody running above 15psi get probs with pinging on a standard engine setup?
What are some of the higher boost levels people run with K03/K04?
Cheers.
Cheers.
