you will have 2 screws covered by caps either side on the handbrake console, then remove the little handrake tab under the handbrake handle you will need a thin stubby screwdriver or similar. the the leather handle will slide off, then remove rear ashtray, unbolt the armrest if you have one, might be some bolt/screw under the little console carpet. slide the rear console back a bit.
1.Then passenger side of centre console another cap.
2. mine is a Symphony HU so that came out 1st, you will find more bolts behind that
3.wedge out HVAC climate next
4. hazard fog trim off more bolts
5. ashtray more bolts
6. flip off gear stick surround should pop off
7. pull out centre console all this for 1 clip will be dead centre above the hazard switch area
think thats almost it
