Maybe this is a good place to ask some questions??
I am trying to change out my damaged drivers front door on a 2000S4 with a good used one from an A4. I have a couple of issues.
First, the trim at the top of the door is a different colored aluminum. S4 smoked sliver. A4 bright silver. The S4 trim comes off easily but the A4 seems to be designed differently so that the metal can not be separated from the rubber window seal. I took the whole damaged S4 door apart with hope that it would make anything I needed to change apparent. That is one complicated door. :\ After removing the window frame and everything else I was able to drill out the rivets that hold the rubber window seal and trim strip as one piece. I do not want to take the replacement door apart to do this on the A4 door. I'm not sure I could get it back together. I could probably get the trim off of the A door if I destroy it but then I'm not sure the S trip would fit on the rubber. The A trim wraps around the bottom at the door edge where the S trip only slips on from the top and can easily be changed. People must have to change out trim occasionally so there must be an easier way to do it than taking everything apart. The way it is it would probably be a 4 hr dealer charge. Just guessing.
The second question is how do I switch out the key cylinder. Once again I took the S door apart to get the handle/cylinder out, which was also very difficult, but aside from doing that to the A door I can't figure out how to just change the cylinder.
Any help? Other better areas to ask this question? Other forums that are better equipped?
Thanks for any help.
