EM TuningMonster Motorsport
Thread: Turbo
    17
    Turbo
    Is it possible for a turbo to not work in a particular gear. I've noticed that I don't seem to get as much pull in 3rd as i did. It feels very flat when I put my foot down. I have a 2000 1.8T Quattro.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    not really, but i guess its possible that its not working in any gear and its just most noticable in 3rd?
    1st and 2nd are over pretty quickly, and 3rd tends to last a bit longer and also is the gear you use most when actually moving, so its quite possible it would seem like the gear affected the most.
    Its possibly a fault which has caused the car to drop into limp mode limiting your boost to 4psi
    Do you have vagcom, and if not whereabouts are you, someone nearby might have a lead.
    TD5 Land Rover Defender build
    17
    I don't have Vagcom no. Is that the diagnostics software? I was messing round with the rear speaker wires from the amp last weekend and I blew the radio fuse. It seems to have started happening after this happened and wondered if I may have shorted something else in the process.
    jcb
    Sep 2005
    uk
    4,070
    what revs?
    17
    Quote Originally Posted by jcb View Post
    what revs?
    It was originally pulling around the 3000 mark but I can't say i'm noticing anything before or after that when in 3rd. The car pulls well in 1st and 2nd but i couldn't say for sure that it's due to the turbo kicking in.
