Sky InsuranceVolks Autos
Results 1 to 31 of 31
    orb
    Carlisle
    57
    Audi Dash Question....
    Hello folks.
    As some of you may have read from one of my previous threads, I have a problem with the Digital Display on the dash of my 1999 A4 SE. (the screen is all pixelated and has lines all over it)
    I want to remedy this, but in as cost effective method I can. A friend of mine works at a breakers of high end cars and has a few A4 clocks on the shelf.
    I know I can fit them, but:
    - Will it work?
    - Can I st it to display the correct miles?
    Any info or help you can offer would be greatfuly received.
    ORB
    Sep 2005
    Worksop, Notts
    97
    You can't just swap them as the immobiliser is inside the cluster. They need reprogramming with specialist tools and the mileage will also need to be corrected
    with similar tools.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,317
    you can pick up vagtacho from ebay for not much money which will allow you to pull the respective codes from your cluster and allow you to code in the replacement one.
    Its worth ensuring the old and new clusters are from the same generation of immo though.
    TD5 Land Rover Defender build
    twostrokepower's Avatar
    Oct 2007
    131
    i say leave it to a specialist as i tryed this and it ended up costing me 700 as had to tow car to audi and get new clocks and have them coded to car
    "Stick a V8 in it!"
    15,317
    You obviously did it wrong then :P
    immo3 is more tricky though, which is probably what your car will have had.
    Oct 2009
    Nottingham
    17
    Also, from my research, it's a relativly common problem, so test the replacement first!
    Dan
    East Berkshire
    178
    A 1999 car could be an original or facelift model and there was a changeover period as the factory used up existing stocks so you ca n find a bit of a mix and match!
    I recently got ours done for 160, while I waited ( less than 1.5 hours) but it was in Great Yarmouth ( was in the area on holiday !! ) .... not exactly the centre of the universe ... however the company is also in north London ( and I believe Norwich).
    They do a number of different car makes.
    They do do mail order, but you would be without the car for a few days if that's likely to be a real problem.
    It was a brilliant job, completely new display, that matches and with new cables and connectors to eliminate part of the original problem.
    I also have a five year guarantee...........
    Cluster repairs UK
    01493 300716
    www.clusterrepairs.co.uk
    0208 986 4100 Edmonton N18 3HT
    no connection other than a satisfied customer.
    ChrisG
    Milton Keynes UK
    248
    I remember seeing a post on here a few years ago where someone detailed how to fix the DIS.
    All it was down to was Dry Joints.
    Costs nothing but a few hours of work if you know what you are doing with a soldering iron.
    East Berkshire
    178
    depends if it has missing pixels or a damaged LCD, mine had both... (mine ? .... it's hers !! but I get to fix things and fill it up with fuel !!! )
    Info was on a A3, it did look simple enough to do.
    ChrisG
    Milton Keynes UK
    248
    Just Googled......
    Found a link - http://www.nynexonline.co.uk/storage...lay_repair.php
    Looks like it allows you to download a ZIP file, unable to check this as I am at work and they are blocked by the proxy server.
    By looking at the A3 post, users say it is easy to follow.
    Jim.
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    Quote Originally Posted by Kingfisher View Post
    Cluster repairs UK
    01493 300716
    that link dont look right this is the one http://www.clusterrepairsuk.co.uk/
    looks interesting not a million miles away from me
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    orb
    Carlisle
    57
    Hmm, so, is the common thing to fail the LCD or just the connecting ribbon? The guide seems to show that you just put a bit more pressure on the connections and all is well. But others tell me you have to replace the whole LCD display.
    I am a bit confused.
    Oh, I am think that my car is a facelift, it has the later headlights at least. Are there any other give away factors?
    Sorry for all the questions, but I like to learn and do stuff myself if possible.
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    loads of differences, do you have any pics of car ad?
    some more info here on facelifts about 2000 differences apparently
    Quote Originally Posted by Road Razor View Post
    A4 1999.5 changes.
    orb
    Carlisle
    57
    Yup, mine is the later one. I dont think it has the ESP though, but it is auto, so it may not??
    East Berkshire
    178
    there were 1999 facelift models ( often seem to be refered to as 1999.5 ..... they were manufactured May 1999 onwards --- ours was one of these as it was ordered as soon as the model was announced in April and delivered in July).
    These were not drive by wire, they had a throttle cable.
    Ours most certainly does not have ESP.
    Also has an analogue clock .
    2000 models had dbw, digital clock, and various other bits.
    I have also found out recently that the 180 bhp 2000 models, basically the quattros, got a KO3s turbo.
    as an aside:
    My 2000 model A3 T Sport ( very end of December, curved door handles) should have had dbw but actually had a throttle cable.... but a digital clock...vagaries of production ?
    ChrisG
    "Stick a V8 in it!"
    15,317
    kingfisher: the 180hp DBC cars just got a standard K03.
    Its the 2000> DBW cars that got the K03-029 known as the "K03S"
    orb
    Carlisle
    57
    Mine is a September 1999 A4 and I have never looked to see if it is DBW or not, but it feels like it on the throttle pedal. I have a Digi clock and I cant find an ESP switch.
    East Berkshire
    178
    Throttle cable is easy to see under the hood, on top of the intake assembly towards the driver's side ( iirc ).
    Umm, difficult to tell by registration date when it's September as they could be 'old' 99 models or 'new' 2000.....but then see my previous aside about my December 1999 , 2000model, A3 T Sport, digital clock but throttle cable .
    ChrisG
    orb
    Carlisle
    57
    Hmm, my car is a V6 so i would have to pull off the plastic cover. I cant be bothered!!
    "Stick a V8 in it!"
    15,317
    if its a 30v its DBW
    orb
    Carlisle
    57
    Yup, she is a 30 Valve
    To go back on topic, what does 'Dry Joints' mean in leymans terms?
    I have a man (micro electronics engineer) who said he could replace the screen easy enough if I gave him the new screen and stripped down the cluster.
    If 'dry joints' is what I think it means (dead solder?) then is this something he can do?
    Does that make sense?
    Jun 2004
    Northants
    126
    My car had this display problem for about 5 years. I would fade badly when it was warm. This year, it's gone completely.
    Has anyone else had this problem.?
    Beginning to miss it now... even though it was barely readable. :-)
    East Berkshire
    178
    I would say that there are thousands if not tens of thousands of owners with the same problem - not just Audi either!
    Orb, if you have a man like that then you have little to loose , let him have a look.
    ChrisG
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    Quote Originally Posted by orb View Post
    you will know if yours has an ESP as its next the fog switches and in place of the blanking in the centre console. IIRC ESP standard on S4 between late 2000 - 2001
    orb
    Carlisle
    57
    Mine is not an S4, and there is NO esp button, but then mine is late 1999. It is a 2.4 V6 30v Tip SE Avant.
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    ahh same engine and box as mine
  28. #27
    diffas's Avatar
    Lahti, Finland
    131
    Add diffas on Facebook Visit diffas's Youtube Channel
    Hi! I'm new on this board. So don't shoot me down.
    I was clickin around German ebay so I ordered unintentionally (didn't know what I was clicking) to myself new FIS tachometer "8D0920930".
    So is it even possible to replace my old one "8D0920900" with the new one I ordered. Both are facelifters and from 2.5v6TDi. I think I need atleast
    multifunction wheel or new multifuntion wiperlever. Right? What else I need to know about swaping those?
    Slow and smoking - A4 2.5TDi+ 220+kw
  29. #28
    calvin's Avatar
    parked up
    Oct 2007
    Sunny Sussex
    155
    Whilst your car may not be an S4, have a squizz through this thread:
    http://www.audi-sport.net/vb/showthr...h-clocks-in-S4
    If you are looking to simply replace the DIS screen, then I think you can - I had mine to pieces and its relatively straightforward to replace a like-for-like component (if the replacement already works!).
    Alternatively, I would also highly recommend ClusterRepairs - give em a ring, they repair DIS from 70 all in.
    Or, follow the thread above, and see that you'll need VAGTacho, VAGCOM and a cable to get the codes off and recode the new clocks into your car.
    '98 S4 with MRC remap and gutted pre-cats - Now SOLD.
    '70 Siva Minibug beachbuggy with Supercharged 1275 A-series
    '89 VW T3 Westfalia poptop 2.1 petrol
    '52 RenaultSport Clio 172 Cup
    '52 Smart FourTwo (it is a turbo!) for when everything else is being mended...
  30. #29
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    Quote Originally Posted by diffas View Post
    are you trying to replace a cluster without dis screen?
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
  31. #30
    "Stick a V8 in it!"
    15,317
    i think the 900 cluster has some kinda partial dis
    see here:
    http://cgi.ebay.de/Tacho-AUDI-A4-V6-...15151002r28591
  32. #31
    diffas's Avatar
    Lahti, Finland
    131
    Quote Originally Posted by olds_kool View Post
    I want to replace the whole thing. I wanna see oil temp and the voltage + consumption.
