Sky InsuranceAH Fabrications
Results 1 to 12 of 12
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    1.9tdi gear linkage fit 1.8t?
    are the two interchangeable? i could do wityh a new one and there is one at my local breakers on a 1.9 tdi but not sure if it will fit on a 1.8t. anybody know?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,949
    I would imagine the transmissions are the same.
    TD5 Land Rover Defender build
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,361
    5 Speed linkage is the same across the range.
    May 2008
    perth
    1,197
    thats what i like to hear. just need to check if the bush is ok on it now.
    May 2008
    perth
    1,197
    It's not quite the same. Where the rod that goes to the gearbox mounts under the car it's turned round 90deg so the bolt comes in from the side but on my car it comes in from the top. They must have changed it for facelift cars.
    CraigG's Avatar
    May 2008
    188
    was the 1.9tdi a quattro aswell?
    Imola S4 - Bilstein B6 + Eibach Prokit, Anthracite BBS Pescara 18x7.5"
    May 2008
    perth
    1,197
    Nope.
    "Stick a V8 in it!"
    14,949
    Facelift linkages are different for sure, its mentioned on that team skittle racing page i've linked you to before.
    He seems to suggest they are interchangable, but the earlier linkage isnt as good as the later one.
    Only the 6 speed boxes have a completely different linkage afaik.
    Apr 2004
    12,361
    all the 01A boxes have the same linkage..... odd.
    Apr 2004
    12,361
    My bad, i have delved properly into this and find there are some with push rods, and some without and they can vary slightly on the actual shift rod, that's the bit that the allen key inside undoes. It seems to suggest not all the vaiations are for UK models and varients.
    So where as so far all i have seen have been the same, it's concievable some random differences are out there. Sorry Ian
    May 2008
    perth
    1,197
    No problem. Its on now. I just had to drill and tap a horizontal hole to mount the shifter rod to the alloy bit on the botton of the gear lever. Im going to try and get a steel bit made at work to replace the bush in the original one then i can swap it back over. With it being a quattro and not having the car on a ramp it was a pain to do.
    May 2008
    perth
    1,197
    Im going to replace the rubber bush in the old linkage with a steel bit and i found a place in the states that sell a kit for a steel bit to replace the bush the same as i am going to do so im not the only one to think of doing this. Just need to drill the bush out and ges sizes now.
