symptoms: this time round im sorting the temperature problem. it takes forever to get up to temp and the temp will not stay at 90
cure: new stat. this as you may know is typically a cambelt off job. mine is almost due a cambelt and there is something making a whiring sound so im doing the lot
cambelt
aux belt
tensioners
water pump
stat
whatever else i find
so far ive faffed getting the bumper off and lock carrier down. lots of things to disconnect
i had to go back and get axle stands from storage (unnecessarily) because i couldnt find any more bolts behind the wheel arches. there are none, but it gave me a chance to get the front up in the air and look at the suspension
anyway, lock carrier is off so ive got access to stuff. aux belt is off and i find the aux tensioner sounds like a bag of nails when i turn it (result)
if not stripped it any further yet. need to research how to get the fan off and ill tackle the covers and order bits tomorrow
the offside variable valve gizmo looks weepy. is this an easy seal to change?
i hope to have it stripped back to the cambelt off tomorrow and get some timing marks on there
the pas pump sounds like a sack of sheet too like there is play in the shaft
anyone know if thats normal?
cambelt
aux belt
tensioners
water pump
stat
