EM TuningSky Insurance
    Turbo Lag FTW's Avatar
    Hate those none insured you know who types
    Feb 2007
    Carlisle, Cumbria. Not Geordie nor Scotch!
    233
    Question Driver Information System not working
    Guys I cant get my DIS to show up, when I press the clock button it runs through the system check ok oil lights and water etc and the display is working fine. But when I press the button on the stalk I get nothing at all when trying to get the DIS up. Also coming from Cumbria weve had a lot of water as you all probably know so Im not too sure if it could be linked to that.
    Any help is much appreciated
    Audi A4 1.8T Sport
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    hit the button on the bottom of the wiper stalk
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    Feb 2007
    233
    Fault found, appears that the Reset button on the stalk no longer works. I removed the fuse for the cluster and upon inserting the DIS screen lit up and I can scroll through the list but cant do anything with the reset button.
    So guessing the next thing to do would be to replace the stalk right? and are they easy to change?
    Audi A4 1.8T Sport
